will removing cats cause stock tbi chip to go lean?
Old Dec 6, 2005 | 02:16 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Well, something's rattling around in one of my cats. I figure I've either got a piece of the cat broken off and stuck in there, or the engine has coughed up a piece of a piston. The only way to find out is to pull the cat and see what falls out.
If it's the cat, I'm thinking about just eliminating the cats and having a "test pipe" made. Since I've moved to Oklahoma, there aren't any emissions inspections, so I can de-smog the car if I want to.
My question is, will pulling the cats cause my stock TBI and chip to go lean? I already noticed it get leaner since installing the headers and exhaust.
Old Dec 6, 2005 | 08:14 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You won't have any problems if you remove the cat. The 02 is upstream of the cat and you can just let the AIR tube vent out in space.
Old Dec 8, 2005 | 09:35 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Re: will removing cats cause stock tbi chip to go lean?
Look at my sig, I don't care, but you made it sound like it was legal or something
Old Dec 8, 2005 | 09:48 AM
Engine: L03 305 TBI
Re: Re: will removing cats cause stock tbi chip to go lean?
Well, there's "legal" where you are in strict compliance with the law, and then there's "legal" where no one's looking.
Old Dec 8, 2005 | 12:23 PM
A drunk old guy told me last night at the bar, "If you are going to be a fool, be a quiet fool."
Old Dec 8, 2005 | 12:37 PM
Engine: L03 305 TBI
A wise bartender once told me: Don't stick your d**k in the fan".
Old Dec 10, 2005 | 10:34 AM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
A wise bartender once told me: "Take your d**k out of the fan."
Old Dec 10, 2005 | 02:49 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
hehe
MustangBeater20
Oct 29, 2022 09:20 PM
NBrehm
Aug 25, 2015 11:49 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
