Junk or not?
Old Dec 6, 2005 | 08:59 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Junk or not?
Well this looks like a good deal for aluminum rockers. I just wanna know if its junk or not cause usually cheap sucks. Also do we have 3/8 or 7/16 studs? Also do I want self aligning ones? Thanks guys
http://cgi.ebay.com/ebaymotors/350-3...QQcmdZViewItem
Old Dec 6, 2005 | 09:01 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
check the search engine but, they are 3/8 self aligning i beleive. They probably are crap no offense. Btw proform another cheapy brand also makes low quality aluminum 1s which i'd stay away from, from here say anyways.
Old Dec 6, 2005 | 09:03 PM
Engine: LB9, LB9
Thanks man, but I checked the search a few days ago and I couldnt find much in the TBI boards. I just wanted to make sure they are self-aligning like I thought. Skinny steel ones are better for stock valve covers right?
http://cgi.ebay.com/ebaymotors/Comp-...QQcmdZViewItem
Old Dec 7, 2005 | 09:50 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You really want narrow body rockers. You want 3/8 self alligning. Those may not fit under the stock vavle covers. I would also advise against cheap aluminum rockers. They tend to fall apart at the fulcrum and the cheap ones aren't usually rebuildable. I would get a set of stamped roller tipped 1.6 rockers (should be cheaper too) and call it a day.
Old Dec 7, 2005 | 03:15 PM
Engine: LB9, LB9
So you think those comp cam ones will fit? They look small and they are steel.
Old Dec 7, 2005 | 03:58 PM
TierAngst's Avatar
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
Don't mean to sound rude but I told you I did a bunch of research and if you're going to go cheap you want the ones I sent you the link on, they're only $70 or so bucks for a set of them and they're going to give you at least 95% of the performance you'd get from the very best rocker arms.
Old Dec 7, 2005 | 05:01 PM
Engine: LB9, LB9
Yeah dude thats right you did send me a link. Is there a rocker I" can compare those ones too? Do they have the roller tips and all? Plus I hope they are 3/8 stud and self aligning.
Old Dec 7, 2005 | 05:17 PM
TierAngst's Avatar
Engine: 355
Transmission: 4L60
They're comparable to these
http://store.summitracing.com/defaul...5&autoview=sku
If the link doesn't work its summitracing part number CCA-1418-16
Yes they are.
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
mfp189
Sep 27, 2015 09:25 AM
armybyrd
Sep 26, 2015 03:37 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
