4.3TBI system in 2.8L engine
Old Dec 17, 2005 | 10:47 PM
Raul_Chile's Avatar
I want install a 4.3 TBI system (ecm, harnes, throttle body, injectos 4.3, sensors, etc) in 2.8L engine.
My doubt is in CFM necesary for 2.8L with this TBI and mixture too rich in 2.8L.
I could job with 7, 8 or 9 PSI to approve mixture too rich?
here in Chile is not easy burn chip to repear this problem. For that my question is simply change 4.3 system in 2.8L
regards
Old Dec 18, 2005 | 04:24 PM
jase's Avatar
you should be able to turn the fuel pressure down on the regualotor.I am not sure if everything will interchange on the 6 cyclinders like V8's but if they do it shouldn't be a problem then.If everything does interchange,set your ful pressure with a guage and make sure if you can get it a inline guage that way you can allways change fuel pressure when needed and too se if your pump is evergoing bad.
Fast355
Dec 2, 2016 06:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
