Will This Work??
Old Dec 25, 2005 | 08:15 PM
a mack6's Avatar
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
Will This Work??
OK i've been itchin to get one of ProForm's Black chevy open element air cleaners from summit. Now i finally got some giftcards and what not and i'm gonna purchase it..however i have 1 BIG question: Will it work for my car??
It doesn't say whether its a drop base or nondrop and i'm not sure whats up with it? Can anyone check it out and give me a heads up as to what it is and to confirm it will work in my car???
Its summit part # PRO-141-752
Old Dec 25, 2005 | 09:14 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
Engine: B5254S Engine
Transmission: Automatic
Axle/Gears: It's a volvo?
any 14x3 inch filter will work for your car. That one you picked is a dropped base one and you will need to go to your local autoparts store and pick up a TBI plastic ring spacer...they sell em' at checker's for 10 bucks, albeit they are not the best quality but they get the job done well.
Your gold iridite ring will not clear that air filter from rubbing up against your ignition wires. So you need to buy those plastic ring spacers that i told you in order to clear any wires. What I did was cut a small piece of cardboard out and I put the cardboard piece in between the wire and the the air cleaner housing.
But in short words, that will work, but really you don't need anything fancy like that. A 30 dollar Edelbrock air cleaner will get the same job done...
Old Dec 25, 2005 | 09:27 PM
a mack6's Avatar
I dont need something like that..but i want something like that...
Now if i use these TBI spacer rings will i run into any hood clearance problems???
Old Dec 25, 2005 | 09:39 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
No you wont run into any hood clearance problems, just make sure you don't over do it. If you want disassemble your air cleaner now, and take out the gold spacer ring I was referring to it. Look at it closely...now the plastic TBI spacers I recommend has a little bit bigger base and then another 1 inch spacer that attaches to the top of it. This raises the air cleaner base slightly
When I installed mine, I had a hard time deciding which one to use, the stock spacer ring was too small and my wires were in full frontal contact with my housing, so I used the bigger base of the TBI spacer and it still rubbed surprisingly, but then I added the additional piece and it didn't rub at all. However just to be on the safe side I still added that piece of cardboard in between the wires and the housing. Never hurts to double check.
You shouldn't run into any hood clearance issues at all. All you have to make sure of is when you finish completely installation of the air cleaner, to very slowly drop the hood checking for hood clearance as you lower. Be gentle closing it from then on everytime you pop open the hood.
Old Dec 27, 2005 | 09:25 AM
a mack6's Avatar
I was looking and there are various sizes of TBI spacers...how tall of a spacer should i get to clear the coil but still have the air cleaner fit under the hood??
.5 inch? .75 inch? 1 inch???
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
