do i have a TBI?
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
do i have a TBI?
i know...dumb question...but every picture i have seen on here of TBI engines run a serpentine belt set-up. i have a '84 Z28 305 with a carb, but the engine uses seperate belts, so, do i have a TBI or is it just a carbed engine? and how can i check?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
A previous owner could have added a serpentine set-up. Chances are this is what happened. To check just full off the air cleaner. If you see two injectors placed in a pod over the intake bores than you have TBI. It will also have "TBI" cast into the top of the unit.
Engine: 305 V8
Car: '90 RS
Engine: 377 LSX
Originally posted by Trah84Z
i don't have the serp set-up...
This is a stock TBI serpentine set-up.
Engine: 305 V8
no, i have the seperate belts and not the serp set-up. i was wondering because all the pics of TBI set-ups i've seen on here use the serp set-up, and was wondering if it was possible to have a TBI with the regular v belt set-up...
Car: '90 RS
Engine: 377 LSX
Car: 1983 G20 Chevy
Transmission: 4L60
You can run TBI with the v-belt set-up.
Car: 1983 G20 Chevy
Transmission: 4L60
Originally posted by TraviZ
v belts dont spool up the tbi plates fast enough, you need serpentine.
rs_z28_vert
Sep 30, 2015 09:47 PM
