will it work?
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Technically speaking, it should run until it burns up.
Proceed with caution.
S-D
S-D
Car: 1983 G20 Chevy
Transmission: 4L60
I wouldn't do it.
You are going to need a way to drastically raise the fuel pressure when under boost anyway. The system only runs at 9-12 PSI any way, now put 8 psi on the outgoing side, you now only have 1-4 psi of fuel pressure, yuck. The factory TBI pump will put out about 15 PSI max. I would go with a Walbro 190, use a FMU with about 4:1 rising rate, retard the timing 2-4*, and go from there.
Keep in mind that Rbob's, EBL is 2 bar MAP sensor compatible for supercharged engines.
Terrell351
Jun 13, 2021 01:13 PM
