Video of two TBI wide open cars and open element
Old Mar 26, 2006 | 07:54 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Video shows two wide open 91 Camaros. Also shows what an open element sounds like I know a lot of people are curious about that.
http://www.customdoorsandhardware.co...p/carstart.wmv
Old Mar 26, 2006 | 10:04 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
nice video helps a lot. did that open element make a difference other than sound?
Old Mar 27, 2006 | 01:03 AM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
why does it seem everyones tbi with a open element is quieter than mine, mine is retarded loud...not complaining but even cars out here with em mine is so much louder even with both hoods up
Old Mar 27, 2006 | 06:32 AM
crrllmich's Avatar
Engine: L03, LS1
It made it more responsive. Plus less clutter.
Old Apr 2, 2006 | 01:14 AM
useful idi0t's Avatar
Car: 88 Trans Am
Engine: LO3
Transmission: TH700-R4
Axle/Gears: 7.5 10 bolt 2.73 open
same thing crrllmich said. my 89 formula had one of those triangular shaped edelbrock open elements on it, and it also had an 84 l69 hood with the solenoid controlled cold air duct (not sure how the hood got on their in the first place) but that engine was responsive as hell. absolutely no lag and loud as a bastard.
i ditched that open element for a summit 14x3 when i got my trans am and its alot quieter, i think it was becasue the old one was just sitting ontop of the TB collar as opposed to being bolted down with the summit piece.
Old Apr 2, 2006 | 04:58 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Mine became 'pleasantly' loud from the front when I put the open air element on it. I have this theory that stock turndown pipes are more restrained sounding than the straight pipes (that I want).
Listen for yourself.
If I got rid of the turn downs and went straight out, I am sure they would sound louder (better?).
~C
Old Apr 3, 2006 | 12:49 PM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
~C
Hey, I always thought it was just my starter that made that odd noise.... I guess it's all TBIs that do. It sounds like a normal starter, but it's just so much different than all the other ones you hear.
Old Apr 3, 2006 | 04:38 PM
VetteC5RFrEak's Avatar
Car: 1989 Camaro RS (w/Z28 tags)
Engine: 305CID TBI
Transmission: Manual - T-5
Axle/Gears: Stock
I think my turndown sounds awesome!
http://video.google.com/videoplay?do...camaro&pl=true
- Chris
Old Apr 3, 2006 | 06:57 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Not very good sounding IMO...
Old Apr 3, 2006 | 08:47 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
I think it sounds good, whats the settup?
Old Apr 3, 2006 | 09:08 PM
Engine: 305CID TBI
Axle/Gears: Stock
Supposedly its a Flowmaster muffler. The muffler is extremely small. It's a cat-back system, or so I was told from the previous owner. Here is a picture of it:
- Chris
Old Apr 3, 2006 | 09:11 PM
Just a single chamber flowmaster...
I don't think Flowmaster ever offered their 1 chamber mufflers with a complete cat-back exhaust system.
Old Apr 3, 2006 | 09:20 PM
Maverick_IX's Avatar
Car: 1991 Chevrolet Camaro
Engine: GM 5.7L H.O. 350HP
Transmission: Rebuilt 700r4/Shift Kit/Servo
- Chris
Have you noticed how the exhuast smokes more when you let off the throttle!?! I think you are running a little rich from the look of all the carbon residue.
What I don't understand is why flowmaster mufflers are so popular. Yes, they sound good but with the metal dividers for the "chambered" effect placed directly in front of the flow of exhaust they creat huge amounts of backpressure that increases with throttle.
Old Apr 3, 2006 | 09:23 PM
Engine: 305CID TBI
Axle/Gears: Stock
I believe it was a custom cat-back job. The pipes aren't madril (sp?) bent like I have seen in bolt in applications. The pipes have the same bends as the Y-pipe, like they were squished together almost. I've just always assumed the previous owner had a shop put it in. However, lately, I have been wondering if it really is cat-back or not.
And yea, I've noticed the large amounts of white smoke. Since that video I have installed the smog pump (being in CA sucks!) and the amount of smoke has diminished quit drastically. We believe we are burning water. When I got the car, the motor was blown. The previous owner ran the motor so long on very little oil. When he went to check the oil there was only a 1/4 of a quart of oil in the motor. So we got a different block and put the heads on from that blown motor. We never checked the heads so they might have a crack in them or don't sit right on the block which is why we may be burning water. The white smoke goes away after running the car for a few minutes.
- Chris
Old Apr 3, 2006 | 10:16 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
It should sound something like this...
http://www.cascadecrew.org/John/johnscar.wmv
MustangBeater20
Oct 29, 2022 09:20 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
