Works better in closed loop!
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Hi, I just noticed that my car has its power and kick back right after I start the car when its idling higher.
The car would run fast, but would hesitate from time to time.
After about 5mins. the idle falls down and the car is a dog off the line.
I have a new bosch sensor 1 wire, with headers. I never had problems with it before, but could that be it ?(changed it after I had my hesitation problem).
Also, I will be datalogging since I don't know what the heck is wrong with my car.
Also, it downshifts way to late from 3rd to 2nd. What would you say would do that. Note I did readjust the TV cable.
I also have a bad rear caliper and I can hear it scrape against the rotor sometimes. I will replace that, but could this cause a problem with trying to do a burnout??
Thanks soo much.
Thanks soo much.
hectre13
Aug 26, 2015 08:17 AM
