Defective
Car: '89 Firebird
Engine: 305 TBI (LO3)
Axle/Gears: 10 bolts 2.73
Defective
Can a defective EGR valve kill gas mileage ?
Sorry, clicked on the wrong box...
-Shifty
-Shifty
Car: '89 Firebird
Yeah when i'm cruising around at approx. 30mph the trans shifts into overdrive , but as soons as its in OD the engines drops really low in RPM's , like 900-1000 rpm ...
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
That sounds normal. OD should shift around that mph under part throttle. If you don't want the car to shift that early than keep the shifter in 3rd until you reach higher speeds.
Car: '89 Firebird
Anyway I reseted the ECM yesterday , took a drive to tech school this morning and I self diagnosed it and the only trouble code flashing was 32 , wich is a defective EGR .
Car: '89 Firebird
There's no fuel leaks and the EVAP system seems ok , so maybe it is the EGR valve ?
(I don't think EVAP as anything to do with fuel consssumption...)
Car: '90 RS
Engine: 377 LSX
That is correct however it may just be stuck and or need to be cleaned. GM EGR failures are very common and have happened to almost every GM car I/we have ever owned.
Replaced EGR's on
'95 cavy
'98 cavy
'90 RS
'94 suburban
'95 Z28
Car: 92 trans am clone
Engine: LO3
yea ive had to do that once to a saturn. the egr valve was stuck either open or closed used some carburetor cleaner and kept swishing it around inside cleaning all the carbon off. and if it goes in and out it works
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
camaroguy99
Jun 30, 2002 03:06 PM
