tbi head port and polish
Old Apr 10, 2006 | 11:04 PM
joshnryandad1's Avatar
Car: 1991 camaro rs
Engine: 3.1
just a few questions, i executed a search but didn't come up with what i was looking for. how much troulble would i have at porting and polishing the lo3 heads and will the computer hate me for it? or should i attempt to install a set of vortec heads or will vortecs even install onto an l03? thanks for any input felllers!!
Old Apr 14, 2006 | 01:46 AM
iroc22's Avatar
Your computer wont hate you. However you might find it kind of tough porting the 187's since they have a shroud which has a water jacket running through it, in other words, you cant get rid of it.
Vortecs would be a much better route IMO
Old Apr 16, 2006 | 11:35 AM
Car: 1991 camaro rs
Engine: 3.1
so the vortec heads will work on my L03? thats what i would like to do in the first place!
Old Apr 16, 2006 | 04:48 PM
DM91RS's Avatar
Car: 91 RS
I've had them on mine since 01.......do a search for Vortec
Old Apr 17, 2006 | 03:47 PM
Car: 1991 camaro rs
Engine: 3.1
dumb question but are the vortecs direct bolt on's or what would i have to do to the Lo3? i have heard alot of good things about the vortecs would a throttle body from a pickup help with the flow or is this a waste of time? i haven't had much experience with computer controlled and am willing to learn all i can! thanks by the way for the replies!
Old Apr 17, 2006 | 05:03 PM
DM91RS's Avatar
Car: 91 RS
The Vortec's as a head are a direct bolt on but you will have to get a "Vortec" style intake whether you buy a throttle body type or a carb type and use an adapter as I did. Go to some parts sites and see what's available.
Old Apr 17, 2006 | 07:20 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Unless you have other mods planned (cam, headers chip work) I would skip a head swap. The stock heads can support almost 300 hp and with port work should surpass that amount. Whatever route you choose will be dictated by your ability to chip tune. It will be required.
Old Apr 17, 2006 | 08:28 PM
Car: 1991 camaro rs
Engine: 3.1
i know i need to tune my chip but it seems like alot of work and i'm not a genius when it comes to chip burning. my brother has a lap top but but i haven't ever tried the process! all cars are not the same thats why a mail order chip wouldn't be beneficial so i guess i need to study up on it! if i ported and polished my heads wouldn't the computer diagnose the change and compensate for the added flow?
i know i need to burn a new chip with the perf mods i want or have but i'm not sure on the process. i have a laptop i just haven't messed with prom tuning! all cars aren't the same so a mail order chip wouldn't be beneficial so i guess i need to study up on doing it. wouldn't the computer though, diagnose the extra flow and compensate for it??
Last edited by joshnryandad1; Apr 17, 2006 at 08:33 PM. Reason: Automerged Doublepost
Old Apr 17, 2006 | 08:34 PM
Car: 1991 camaro rs
Engine: 3.1
Old Apr 17, 2006 | 08:41 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
It will see the added airflow at part throttle and adjust the long term fuel trim to help compensate (BLMs). It would not be the ideal scenario as the stock system is only designed to compensate about 10%. The better situation would be to increase the fuel pressure slightly and work with the chip.
Old Apr 17, 2006 | 09:34 PM
DM91RS's Avatar
Car: 91 RS
I did not see whether or not you had the exhaust or anything else covered. I did headers, 3" exh., better breather and some chip work before adding a cam and then adding a performance intake and the Vortec heads.
Old Apr 18, 2006 | 12:13 AM
Car: 1991 camaro rs
Engine: 3.1
dm91rs, what kind of power did you notice from the headers, exhaust, breather, and chip work? was it quite a bit noticable from stock? i used to have an 86 iroc that i installed a 3" exhaust onto and it made quite a bit a difference.
Old Apr 18, 2006 | 11:10 AM
DM91RS's Avatar
Car: 91 RS
It was quite noticeable over stock. It would pull to higher rpms for sure.
It would have been better if I had more of an understanding back then about the timing tables and how much timing could be safely added.
Old Apr 18, 2006 | 08:19 PM
Car: 1991 camaro rs
Engine: 3.1
i haven't installed the L03 yet, what size of stock exhaust will i have from the manifolds to the cat? i am planning on yanking out the cat and replacing it with a pipe and then a 3" catback from there. hopefully i can scrounge up enought fo a set of headers also when i install the catback that would help out with breathing quite a bit.
Old Apr 19, 2006 | 03:57 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
Probably 2 1/4" pipe all the way, i know my stock cat-back was 2 1/4, and i think the Y-Pipe was also 2 1/4"
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
89-S-dime
Aug 12, 2015 11:57 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
