nitrous on a tbi?
Old May 12, 2006 | 10:57 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
nitrous on a tbi?
What would be the easiest way to put nitrous on a tbi car...I cant figure it out....thanks
Old May 12, 2006 | 11:05 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
add it to the air filter box
Old May 12, 2006 | 11:47 PM
dwillis's Avatar
Axle/Gears: 3:08
My Throttle Body doesn't have an air box...The air cleaner sits on top of the tbi!
Old May 12, 2006 | 11:57 PM
Car: 84' Trans Am
im outta ideas
Old May 13, 2006 | 11:36 AM
boredomkills's Avatar
Car: 1992 rs
Engine: 350 tbi
People were talking about his about 3 days ago if yuou search for it you will find it, but NOS makes a kit that is made for tbi trucks but bolts onto a tbi camaro jsut fine.
Old May 13, 2006 | 01:10 PM
dwillis's Avatar
Axle/Gears: 3:08
thanks...search helped alot...
Old May 13, 2006 | 01:55 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
With a 200,000 mile TBI in my car, could it handle a 75 shot?
Old May 13, 2006 | 02:14 PM
Car: 1992 rs
Engine: 350 tbi
Im not gonna say yes or NO because its hard to say without tearing down the engine or atleast checking the compression but probably not.
Old May 13, 2006 | 02:16 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Unless you've driven those the majority of those 200k miles, I would be hesistant to juice it.
Old May 13, 2006 | 02:27 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
can a dry kit be used or does it have to be a wet kit?
Old May 13, 2006 | 02:30 PM
Car: 91 RS
Engine: 350 TBI
Wet is the smart way to go.
Old May 14, 2006 | 01:31 PM
Engine: LB9, LB9
lol it was beat I think before me, but if the compression was decent, could it maybe handle the 50 shot at least?
Old May 14, 2006 | 04:01 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
It COULD,but not likely that it will.Nitrous on a stone stock,cast piston,low performance engine is dicey at best,but add 200,000 miles of wear,tear,and abuse to one and add nitrous to that.Sounds like a recipe for disaster.
If you are prepared to replace the engine on short notice,do it,and let us know how it turns out.Better yet,have a video camera and film it,if it's pure carnage I wanna watch!
Another option for goofy gas on a TBI is a kit made by NOS,that incorporates the silinoids and squirters into a 14 " chrome open air cleaner.
Old May 15, 2006 | 09:09 AM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
Do not use a dry kit, you will definitely ruin your engine. Since there isnt a sensor that detects how much air flow is coming into the engine (like a Mass Air Flow) then the TBI engine doesnt have anyway of knowing to add more fuel to help compensate for the extra oxygen that the nitrous adds. So when you get a wet system, the nitrous plate that mounts under the throttle body adds a equal amount of nitrous and extra fuel, to make it a decent mixture. All the nitrous does is introduce more and colder oxygen, since nitrous is rich in oxygen and very cold that is the perfect way to get a freezing cold oxygen rich induction. Very smart whoever thought of shooting nitrous into an engine!
Also do not shoot the nitrous below 2000-2500 RPMS, its too much for the engine, even a fresh built motor, just some thoughts!
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
