im stumped
Old May 14, 2006 | 06:28 PM
82malibu's Avatar
im stumped
my 350 tbi will only rev to 1850 and then the block learn and integrator goes to 150 and 158 but if I give it full throttle it will rev fine. all i did is change to a higher flowing fuel filter for my aftermarket pump.
Old May 14, 2006 | 06:36 PM
82malibu's Avatar
Could the injectors be bad?
Old May 14, 2006 | 06:57 PM
iroctj's Avatar
Car: 86 IROC-Z
Engine: 385 TPI
Transmission: 700-R4
Axle/Gears: 9Bolt 345'S
HEY your injectors are too big for this combo!
Old May 14, 2006 | 07:07 PM
82malibu's Avatar
How can they be when block learn is above 128 it means the computer is telling the injectors to put more fuel in b/c its running lean.
55lbs injector are stock in 350 truck
89 cop car had 65lbs but then the car was way rich at 10 psi so i put in truck injectors and cranked the fuel pressure to 13.5 and it ran great for about 3 weeks.
Old May 14, 2006 | 07:18 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Your injectors are probably too small, and the PROM not optimized for your combination. Chip work is key to making power in a TBI.
BTW, stock 350 trucks have 61 lb/hr injectors from GM. 305s got the 55 lb/hr injectors.
Old May 14, 2006 | 08:08 PM
82malibu's Avatar
oh so i got 61lbs injectors there from a 350 tbi truck. but just giving them more psi would give me more fuel. evreything is perfect till 1850rpm then my snap-on scanner shows im insanly lean and it wont rev anyhigher unless i punch it.
But if i turn fp up it runs rich under 1850 rpm and then at 1850rpm it does the same thing unless i stand on it.
Old May 15, 2006 | 02:56 PM
Ronny's Avatar
Q: But if i turn fp up it runs rich under 1850 rpm and then at 1850rpm it does the same thing unless i stand on it.
needs a datalog. needs a tune. then another datalog. etc etc etc.
funny mine runs A-OK in daily cruise mode and lean WOT. tune wont help that. i need more FP!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
djmarch
May 8, 2016 11:32 AM
Quzyle
Oct 15, 2015 03:35 PM
tuningnewb
Sep 23, 2015 07:06 PM
camarohelp
Sep 22, 2015 03:19 PM
