Wont stay running
Old May 27, 2006 | 01:01 PM
90Formula305's Avatar
Car: 1990 Pontiac Firebird Formula
Transmission: 700 R4
Axle/Gears: peg leg
Wont stay running
I just got the car re registered for CT from Florida. It sat for about a year with intermittent periods where i'd take it for a ride. I took it out earlier this week, and it ran fine except the battery was dead so i jumped it. Took it for a couple of blasts up the road. It ran out of gas a little while later idling in my driveway. I Put a half tank in it, it started running like ****. I put two bottles of dry gas thinking there would be moisture in the tank, that didnt help. I filled the tank up the rest of the way today with shell v-power and two more bottles of dry gas. It still runs like ****. It turns on revs to 1500 drops down and almost dies, sometimes it does die. It just keeps doing this, there ar no ses lights so i dont think a sensor for anything is bad. Any ideas?
Old May 27, 2006 | 01:39 PM
Axle/Gears: peg leg
I spray carb cleaner in it and it runs fine for a little while. Nothing guys?
Old May 27, 2006 | 01:43 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Might try changing the fuel filter. It might have sucked up crap from the bottom of the tank. If that fails, check fuel pressure.
Old May 27, 2006 | 05:14 PM
Axle/Gears: peg leg
How do i check the fuel pressure on this? I dont have a regulator so i need to know how to adjust it to.
Old May 28, 2006 | 01:27 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
I'm talking pressure from the pump. There should be a port in the fuel line next to the fenderwell on the drivers side if you have an Lo3. You'll need a fifty $ fuel pressure tester or a good friend that has one. Should be 9 to 13 lbs pressure. Less than 9 you need to change the filter. If that doesn't help, a new fuel pump will be in order.
Old May 28, 2006 | 06:33 PM
Axle/Gears: peg leg
pound and a half of fuel pressure.....AWESOME!!!!!!!!!
Fronzizzle
Mar 18, 2019 08:29 PM
apo_bailon15
Mar 28, 2016 05:20 AM
ezobens
Aug 19, 2015 10:29 PM
Sherpajames
Aug 7, 2015 06:56 PM
