13.6@98 TBI
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
13.6@98 TBI
Figured id join in on the TBI accomplishments.
I sent a 92 RS with a bone stock L31 and a holly 670 TBI from a 14.1@90 to a consistent 13.6@98 on a first run basic tune i worked on last weekend. Theres plenty more to be gotten from it. I copied over the Vortec Timing Table and it alone made a drastic difference in its unmodified form. I still havent even changed the VE tables from he stock LO3 program.
"TBI" is moving on up
Although i still love me TPI.
Although i still love me TPI. Supreme Member
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Very nice results for a TBI I almost bought a 91 but I was told TBI was terrible....but with that number nice!
What mods do you have done any nitrous?
Jay
Jay
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
8 mph from tuning.....thats 80 HP ladies and gentelman.
If thats not a poster child for tuning I don't know what is.
Good job!
Good job!
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Thanks guys.
The mods are as follows:
97' Tahoe L31 Stock from block to valve covers
RPM Airgap intake
Holley 670 TBI
@15-17psi AFPR
Flowtech Cheapo Headers
Cutout
2200-2500 stall
stock suspension with homemade boxed LCA's
air shocks
This car is plain raw off the line pulling 1.7 60'.
When you get results like that, you never want to stop.
RPM Airgap intake
Holley 670 TBI
@15-17psi AFPR
Cutout
2200-2500 stall
air shocks
Car: 84' Monte
Thats funny, thats about the same combo I'm running only I had a 218/226 dur. cam and stock heads, ok it's not the same, but you get the idea of how much more cam you have to run in order to make the same power as vortecs do. I ran a 13.8 at 97.5 I imagine you would break into the 12's with a cam swap.
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I thinking about a cam and some new RR's. The flow is there in the heads, its just getting it out of em'. Hence going for a cam.
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Originally Posted by GodOverYou
1.7's with 2.73's and street tires?
Car: check
Engine: check
Transmission: check
I think some folks are speaking too soon. I do not see anywhere where 91GTABird claimed he is using street tires and 2.73's. . .
(hint: ignore his side bar: it is a '91 GTA with an LB9. His post speaks of an '92 RS {which is a CAMARO!} and an L31.)
RBob.
RBob.
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
just to clear it up a bit hes talking about my car we wored on the tune last weekend and I ran it the weekend and it ran 13.61@99 you can read my sig. for mods but yes it was on street tires but 3.73 gears.
Car: 91 RS
Engine: 350 TBI
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
1.7 60 foots on street tires is STILL something else. thats near unheard of. what size tires you on and the brand name of them?
and running 14.1 at 90mph is also VERY impressive. actually crazy impressive. 14.1 is DAMN good ET for that mph. i thought it was nearly impossible to hit near 13's with mph less than around 93-94.
just impressive what you have done so far man.
Car: 1983 G20 Chevy
Transmission: 4L60
1.7 60 foots on street tires are not un-obtainable. Hell, I am cutting 2.04-2.07 60 foots with my 5,500# van. I cut a 2.18 with a 305 in it.
The low-mid range power of a properly tuned 350 TBI can be impressive.
Car: check
Engine: check
Transmission: check
RBob.
Engine: forged 350
No I dont have any dyno #'s yet and as far as the tires I have 275-50-15 bfg's but they only hook up good at the track and the cam am running is the stock l31 vortec cam I think its like 410-427 lift or close to it.
If he says he cut it, fine, he cut it, (I wasn't there, I'm not going to call him a liar) but I did have to read it several times just to be sure I was reading what I thought I was. That's just one heck of an impressive 60 foot for what he's got going on... hence the
.... Member
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Jeez, and I just got my AFR 180's in for my 350 that I'm building. Now I'm happy I've got TBI
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Well, that's some good stuff. I know what to look forward to with my set-up, without the nitrous. hehe.
Engine: forged 350
Well my 60' are so good because the track was well preped and you gotta think the stock l31 made 330ft lbs @ 2800 rpm and my stall is just under that so after my mods it has to be more that 330 it has a ton of low end power and pulls great to 5500.
....with a completely different intake, and a proper factory tuned ECM, or at least one of meeting the ODB2 standards. Right now you are running a different intake which can/will considerably affect the powerband, and likely to be incorrect VE calcs. What I'm saying there is don't count 330ft/lbs and go up from there, because you don't know for sure you are still making the base line 330; it could be more or less.
That being said, I think you have by far the best idea for a cost effective motor swap out there. I have been toying around with the idea of building a 350 vortec TBI car, but DUH! why not just get a vortec 350 motor complete instead of parting one together. I also think it will make a great little engine, once you get the tuning all 100% ironed out. Well, okay, who am I kidding... nobody is EVER just "Satisfied" with their tune, they've always got to be playing with something, but still.... great idea for a motor swap.
Transmission: 2004R
That is pretty much the engine I have, the vortec 330/350 motor. but is had 9.75:1 compression and a bigger Comp XFI cam. I I can get the converter ironed out I'll be at the track VERY SOON. To post some times. If you get the VE table straitened out and get down to the track again, please post the times. This is a good thread for those who said TBI isn't any good.
Car: 84' Monte
Not to nitpick....but Godoveryou (nice name by the way
), a panhard bar does nothing for strait line traction.
), a panhard bar does nothing for strait line traction. Thread Starter
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
This first tune was nothing more than to situate some driveability problems and get a baseline for the timing. IM not just gonna throw some over sized numbers in the VE tables right off the bat just on a hunch. I do datalog for a reason.
Given that he hasn't adjusted his VE tables, I wouldn't say it was "properly tuned." Of all people Fast, I highly doubt you would suggest that the VE tables of a LO3 and a L31 can be THAT similar - so much that they could be interchanged.
Lets just not get an infamous TGO pissing contest started again.
And thanks Rbob on the clear-up with the rear gear.
Car: 91 RS
"First run , basic tune" I can not stress that anymore. And who are you tell me somethings not "properly tuned". It seems to me that i was the one that made the post of dropping a 1/2 second off an e.t. from a "BASIC" tune.
Congrats on the progress. It's great to hear positive results. And to the 60' times it's been done before....
ben73..... My 383 TBI (Crossfire) ran a best of 12.81 @ 107mph last year. 60' was 1.76sec on normal street tires
This was not his best time but it goes to show what can be done on the same tires that I run......Falken 255-50-16's
Bmonte - Uh yes it does. When the rear loads during launching or shifting, the PHB can and will flex, causing the whole rear track to move sideways, braking traction.
91GTABird - I am the guy who's making the logical assumption that an L03 and a L31 do not have the same efficiencies at every RPM. There's no pissing, but are you the guy to say that they are just as efficient everywhere in the powerband?
Car: 84' Monte
God, no it doesn't. There is no side force generated when launching a car, deffinately not enough to flex a pan hard bar. When a car kicks side ways it's because one tire looses traction before the other, usually the right side. We can discuss it furthur in PM's or in the suspension forum if you'd like.
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
We havent gotten a change to adjust the VE tables. I would be interested though to see what a stock L31 VE table looked like though for a little reference. Plus after that i can add on the factor of the Air Gap, Ult. TBI Mods, Ram Air (Def. up top), and full on exhaust.
What would your suggestions be Godover? Do you have acces to a L31 or the like VE table?
the_hamturdler
Sep 30, 2015 12:50 PM
