some questions about my non EGR setup
Old Jun 13, 2006 | 09:04 PM
DIABLO NEGRO's Avatar
Car: 1985 project SC
Engine: LSX (planning stages)
Transmission: (planning stages)
Axle/Gears: (planning stages)
ok guys i just got the car fixed and i now i am checking all the little stuff!! yay!!
the intake gasket is leaking in the front and back (my fault with the rtv ) and the timing is almost set right. now i got the edelbrock performer intake without the EGR. now i havent gotten the headers yet i am still useing the stock exhaust manifolds for right now. now i will be tuning it soon so the prom is stock. on the test run when i stepon it the car looses all power, is that becouse i need to tune the EGR out or is that something else? Just checking all the bases so i know what to do next ... thanks all
Old Jun 13, 2006 | 11:49 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Make sure to set the timing with the EST bypass wire disconnected. It is a tan/black wire going away from the distributer and will have a connector inline. Disconnect it and set the timing at 0-6* BTDC.
Old Jun 14, 2006 | 12:15 AM
ok damn i need to go buy a timing light i was tryin to get away with not useing one but lol
Old Jun 14, 2006 | 12:21 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
You don't have to have a timing light to get it set properly. Turn the engine over until the mark on the balancer lines up with 4* BTDC on the pointer. Then remove the cap and rotor. Now loosen the hold-down an line the star wheels up point to point (should be the nearest ones, just requiring a little tweak.
Old Jun 15, 2006 | 08:55 PM
do you have a picture?? it would make it easier does it matter that i have the msd distributor? sorry not very experienced at setting timing
mdtoren
Aug 23, 2015 12:52 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
camaroken83
Aug 10, 2015 11:35 AM
