I want to get an aftermake dual plane intake manifold. I have a 1991 350 TBI. What can I put on there or what would you suggest that is emission legal with EGR setup and all that. It has to pass emissions.
edelbrock makes a stock replacement unit. holley makes one for a 2.00 inch TB unit. some bore the edelbrock to accomodate the 2.00 inchers.
Quote:
Do you have anyclue on what kind of performance either of these would give me, or which wouldbe better? Ya, I want somthing that will just bolt right on without hardly if any mofifications. ThanksOriginally Posted by Ronny
edelbrock makes a stock replacement unit. holley makes one for a 2.00 inch TB unit. some bore the edelbrock to accomodate the 2.00 inchers. HOLLEY REQUIRES MINOR THROTTLE LINKAGE MODS. cant speak for edelbrock. performance enhancement? i thought the exhaust needs work first.
Quote:
How hard is it to make the linkage mod, does it tell you how or do you just have to use common sense?Originally Posted by Ronny
HOLLEY REQUIRES MINOR THROTTLE LINKAGE MODS. cant speak for edelbrock. performance enhancement? i thought the exhaust needs work first. Junior Member
i used the edelbrock 2704 (it think thats the number) non EGR all i needed whas the TBI mounting adapter 50 dollars plus shipping. and the linkage stays the same ... tho it feels a little stiffer but it might be that i havent driven the car in about 3 months
Ya, my only problem is emissions. I have to have an EGR hookup otherwise I wont be driving the car in 2 years unless I switch back to stock, but that would be a pain in the *** to do every 2 years. I am jsut wondering what all I could put on my car that has the EGR hookup.
Brandon
Brandon
Fast355
close
- Join DateJan 2005
- LocationHurst, Texas
- iTrader Positive Feedback100
- iTrader Feedback Score(2)
- Car1983 G20 Chevy
- Engine305 TPI
- Transmission4L60
- Axle/Gears14 bolt with 3.07 gears
- Liked:508 Times in 436 Posts
Quote:
Brandon
The Holley Projection intake would be best for you. It will need linkage "tweaks" . a 1" TBI spacer, and an EGR valve meant for an older carbed 350 chevy.Originally Posted by XxGeinNothingxX
Ya, my only problem is emissions. I have to have an EGR hookup otherwise I wont be driving the car in 2 years unless I switch back to stock, but that would be a pain in the *** to do every 2 years. I am jsut wondering what all I could put on my car that has the EGR hookup. Brandon
Quote:
Will that still give a good result in the emission testing. I have a 350 swap, but I still have to pass a 305 because that is what my car is origianlly. Originally Posted by Fast355
The Holley Projection intake would be best for you. It will need linkage "tweaks" . a 1" TBI spacer, and an EGR valve meant for an older carbed 350 chevy. what do you think the spacer and everything needed will cost me?
Fast355
close
- Join DateJan 2005
- Car1983 G20 Chevy
- Engine305 TPI
- Transmission4L60
As long as the chip is RIGHT there will be NO noticeable difference in the tail-pipe output of a 305 or 350. The 305 makes a little less C0 and HC.Originally Posted by XxGeinNothingxX
Will that still give a good result in the emission testing. I have a 350 swap, but I still have to pass a 305 because that is what my car is origianlly. what do you think the spacer and everything needed will cost me?
Alright, thanks, I will look into that Holley
