horse power for cheap
Old Jun 21, 2006 | 02:14 PM
camarodrew's Avatar
Car: 91 rs
Axle/Gears: 4.10
i have a 91 rs camaro with a 350tbi 700r4 and i have to pas emissions the car runs consistint 15.90s are any super cheap tricks i want to try for 14.50s is that reasonable? oh and i can do all the work myself
Old Jun 21, 2006 | 02:31 PM
z28b88's Avatar
Car: 1988 Chevy Camaro
Engine: 2.8l V6 MPFI
Transmission: 5-speed
its free and easy
Old Jun 21, 2006 | 02:32 PM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
exactly
Old Jun 21, 2006 | 02:35 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Those times sound a lot like a stock 305 car would run.... are you sure its a 350? If it is what mods have you done, a mild 350, in good running order, should easily capable of mid 14's
Old Jun 21, 2006 | 02:40 PM
camarodrew's Avatar
Car: 91 rs
Axle/Gears: 4.10
i just put the the 350 in and i forgot to say the time were from the original 305
Old Jun 21, 2006 | 02:44 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
My experience is all mods,tourqe,horsepower cost money,and you get what you pay for.Also depends on your idea of cheap.If you have to pass emissions i dont know anything that will give you that much of an improvement unless your atleast willing to spend a couple hundred dollars.In MS we can cut or cars and take off the smog pump because they dont check it.Maybe a homemade cold air intake,or disconect the smog untill your emissions test.Its pretty damn easy and i'm no mechanic.Maybe you can find something in the search or someone else has an idea but unless someone gives you something i dont know many other way to get SUPERCHEAP.Good luck
Old Jun 21, 2006 | 02:52 PM
chevypowered's Avatar
Car: 86 Firebird (T/A) Clone
Engine: 2.8L P.O.S (for now.....)
Axle/Gears: 3.23 (woot)
for under $200 at either jegs or summit, a set of 4.10 gears will make it seem like a new car, or you could even ask around in the for sale section to see if anyone else has a set for sale.
Old Jun 21, 2006 | 03:45 PM
gray89vert's Avatar
Engine: 305 TBI LO3
no no, 4.10 gears is waaaay too high. My car has 3.73's and that is too high still in my opinion. You get more acceleration by a long shot but on the highway dont plan on any high speed.
Old Jun 21, 2006 | 04:17 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Since it has a 350, and you have no track times for it, if it is running descently, why not run it, and see what the old girl is capable of.
Old Jun 21, 2006 | 04:54 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
That motor will necessitate chip work. If you are running on the stock tune you aren't making use of that 350.
Old Jun 21, 2006 | 05:32 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Old Jun 25, 2006 | 11:04 PM
okmaro's Avatar
Car: Red 1991 Camaro RS
Engine: 5.0L 305 TBI
Am I understanding correctly that you ran those times with a 305 in your car, but you just dropped in a 350, and you want to know how to lower your quarter, before you even see what the new motor does? Just run the darn thing, see where you are at now with the 350 you just put in, then worry about your time. The car you have may as well have never run the 305s time because a 350 is a whole different animal. If it’s a decent 350 the car will be completely different at the track. Do you have any ideas on hp/torque numbers for your new 350? There’s the major question. The 305 you had has sucky hp but decent torque so off the line it will seem different, but not as drastic as you might think, especially if you have an underperforming 350. With a 350 your acceleration will be better (more cubes = more torque) and you will find your top speed in your quarter will be a lot better (more hp). Just race it and then plan for faster times.
Old Jun 25, 2006 | 11:33 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
A TBI 350 and a TBI 305 have very little difference in HP output. The 350 usually makes around 30 ft/lbs more torque though. The HP difference is usually less than 20. It is probably even less of a difference with the exhaust nature of the L03. The WHOLE stock exhaust is HORRIBLE!!! on a 305, much less a 350. Then add in the fact that he is probably still using the 305 ECM, Injectors, Knock sensor, etc, it is likely that the 350 runs WORSE than the 305 did. For $200.00 I would invest in a 350 ECM, 61 lb/hr 350 injectors, AFPR, and 350 knock sensor.
Old Jun 26, 2006 | 11:03 AM
camarodrew's Avatar
Car: 91 rs
Axle/Gears: 4.10
thanks guys i ran the car it did 90 at 15.04 is that good for a 350 i never really was into drag racing just wanted to see what it would do and uh im getting 300 bucks so any other ideas on what to get to help me into the 14.50 or is this just wanting to much for to little
italiano67
Dec 11, 2016 09:21 AM
evilstuie
Apr 14, 2016 08:52 PM
dutch930
Sep 11, 2015 06:58 AM
Chevy3shitty
Sep 1, 2015 02:10 AM
sailtexas186548
Aug 24, 2015 10:11 PM
