305 tbi on 350??
Car: 90 Camaro RS
Engine: 350 TBI
305 tbi on 350??
I just changed out the 305 tbi for a 350 tbi but we for some reason kept the intake from the 305 and put on it, it seems to be lacking a lot of power, i also think my distributer may be part of the problem but does anyone know if that intake would cause any problems?? ps. the reason we kept the intake is because the 350 we put in was carbureted!
Car: 1983 G20 Chevy
Transmission: 4L60
The Intake and TBI are the same. The 305 uses 55 lb/hr injectors (White/Green) while most 350s use 61 lb/hr units (Orange/Black). You need 2 350 injectors, a 350 ECM, and a 350 knock sensor. Your power will be much better with those 4 items.
Car: 90 Camaro RS
Engine: 350 TBI
It depends on what you are doing if you put in a 350 and keep the same fuel system you just need to change the injectors if you switch from tbi to tpi you can just change the prom and injectors to a 350
