gust put on the 1.6 rrs
Old Jul 24, 2006 | 11:44 AM
t-rex_camaro's Avatar
Car: 1991 camaro rs
Transmission: auto
Axle/Gears: 2 axles and a set of gears
i gust put on my 1.6 roller rockers from sumit. they feal good and clear the covers with no problem. in all i have an ok cam and rocker set up. .465 on the lift for both. and the 1.6s. do u think its to early to get valve springs. i only have about 98k on the 305. its a 91 rs. well thanks for anyhelp you guys have provided. bye
-jake
Old Jul 24, 2006 | 06:09 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
stock valve springs would never be able to keep that engine happy, my guess would be that someone has already swapped them out.
Old Jul 25, 2006 | 10:11 AM
Car: 1991 camaro rs
Transmission: auto
yea well if they are stock do u think i should swap in a new par. i only have 98 or 99k miles on it and i got the car with 83k
Old Jul 25, 2006 | 05:13 PM
TierAngst's Avatar
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
The stock ones are garbage, you can probably get a couple hp in the top end on a completely stock motor just by replacing them. So yes you should get some new ones.
Old Jul 25, 2006 | 05:23 PM
Car: 1991 camaro rs
Transmission: auto
will it hurt it if i dont swap in new ones for a month becas i realy need a tune. school starts in a month 1/2 and i realy need a tune to get some gas milige back. i could get springs in befor school but i thik the tune is needed more
Old Jul 25, 2006 | 05:59 PM
TierAngst's Avatar
Engine: 355
Transmission: 4L60
Get yourself the tuning equipment and just get a cheap set of springs, for about $30 you can buy a complete set that are a lot better than stock. If you break a spring, that tune you just got isn't going to do a thing.
Old Jul 25, 2006 | 10:27 PM
Car: 1991 camaro rs
Transmission: auto
true. but if i get springs im not geting a cheep set im geting good ones the first time.
Old Jul 26, 2006 | 06:57 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
After looking at the cam specs in your other post, that cam has .465 lift with stock 1.5 rockers with 1.6 rockers it has .496 lift..... your stock heads even on their best day would only clear between .460 and .480 lift. Every head I've ever measured was touching the valve seal at .480 lift and you're supposed to have .050 clearance to make sure you never kiss the seal.
If you haven't done it already, you are going to round off some cam lobes. A set of springs just isn't going to cut it. They will better control the valvetrain and prevent coil bind, but you'll need machine work to increase your valve seal to reatainer clearance.
Old Jul 26, 2006 | 11:53 AM
Damon's Avatar
Good cheap springs that will drop in with no modifications: Comp 981s. Look around, they're reasonably priced and have considerably more pressure than stock ever did. They even work well on mild roller cams even though they are typically supplied with flat tappet cams. Stock springs are barely adequate for a stock cam. ANYTHING performance oriented and they won't keep up. Espeically with 1.6s, they'll never keep up.
Agreed, if you're adding 1.6 rockers to a cam with .465 lift using 1.5s you're over .490 and beyond what just about any stock factory head can handle with retainer-to-guide clearance getting real tight over .470".
Old Jul 26, 2006 | 01:38 PM
Car: 1991 camaro rs
Transmission: auto
so what is soppose to go wrong. becas i drove it over 50 miles now and nothing has. or is it hard to tell what has gone wrong. everything seams fine to me. it runs fine idles fine. it even feals better than with the 1.5s.
Old Jul 26, 2006 | 02:04 PM
BMmonteSS's Avatar
Car: 84' Monte
Basically your valve retainer will crush into the valve seal, if you're lucky the seal will have enough give that it won't instantly bend a pushrod or round off a cam lobe.
What WILL happen is that over time the extra force from your retainers bottoming out will round off your cam lobes. Might have already happened, might take a while. If you hear any kind of valve tick it's already happened. I rounded off a few lobes once and couldn't hear it over the normal header tick.
Your best bet is to pull a valve cover pull a spring and measure your actuall seal to retainer clearance. Really there is no reason to, I can say with almost certainty that it's touching.
Old Jul 26, 2006 | 02:06 PM
Car: 1991 camaro rs
Transmission: auto
so say every thing is ok. and i put the 1.5s back on can it still run fine
midge54
Dec 27, 2019 04:14 PM
Cameeeero
Sep 18, 2015 04:00 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
happyhapka
Aug 15, 2015 04:42 PM
