Please Help, completely stumped.
Old Jul 25, 2006 | 01:16 PM
96ta(nick)'s Avatar
We have a 350 TBI motor in our boat and it has had a problem with fouling the spark plugs to where they will barely fire at all. We have replaced every sensor and the fuel injectors. Timing is dead on and fuel pressure adjustments have no effect on it. It seems to bog and then pick up fine when you slowly increase the throttle to WoT but when you give it wot from idle it with DUMP fuel in and then backfire out the intake. I am new to TBI motors and can't figure this out. Any help would be greatly appreciated.
Also the entire ignition system has been replaced.
Thanks,
Nick
Old Jul 25, 2006 | 08:34 PM
Chadster86S10's Avatar
Might not be advancing the timing.
When you checked your timing did you unplug the spark control module?
What kind of distributor? Vaccum advance or electronic?
Is your Spark control module good or new?
Old Jul 26, 2006 | 01:52 PM
96ta(nick)'s Avatar
It has an electronic advance. The spark control module has not been replaced. How do you test it?
When I set the timing i unplugged the module, yes.
Old Jul 26, 2006 | 02:30 PM
96ta(nick)'s Avatar
UPDATE: The module was bad so i replaced it but it did not fix it. It is still backfiring out the intake. Any ideas?
Old Jul 26, 2006 | 06:56 PM
Plug wires on the right cylinders? I've done that before. Something is wrong with the timing.
Old Jul 27, 2006 | 03:59 AM
contact's Avatar
Engine: sbc 350
you might think about changing the plugs
to 'hotter' plugs
Old Jul 27, 2006 | 02:41 PM
96ta(nick)'s Avatar
Wires are fine we have checked them over and over. Plugs are NGK TR5 gapped at .040.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
6speedIROC
16
Mar 15, 2023 08:33 PM
sailtexas186548
Feb 17, 2017 03:07 PM
camarohelp
Sep 22, 2015 03:19 PM
Ranbo108
Sep 9, 2015 12:20 PM
