TBI and Swirl Port heads..
Old Jul 30, 2006 | 05:12 PM
83Chevy_Camaro's Avatar
Car: 1988 Camaro
Engine: 1988 chevy pickup 350 TBI (rebuilt)
Transmission: 700r4- Bowtie overdrives
Axle/Gears: 2:73's
how do i know if i have swirl port heads?
Old Jul 30, 2006 | 05:51 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
pull your driverside valve cover and look for a casting #.If it's an 88 then your more than likely to have the swirlies.I believe the Full casting number is 140101187.
Old Jul 30, 2006 | 06:47 PM
Car: 1988 Camaro
Axle/Gears: 2:73's
Now if i have swirl port heads, What kind of heads should i get? and what kind of a diffrence will i notice? anyone got a Dyno?
Old Jul 30, 2006 | 07:19 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally Posted by 83Chevy_Camaro
Now if i have swirl port heads, What kind of heads should i get? and what kind of a difference will i notice? anyone got a Dyno?
The stock heads are capable of supporting 300hp and with port work they will support more. If your motor is stock you have other bottlenecks that are limiting power. Swapping heads would yield no power difference because of the other bottle necks (cam, exhaust). What are your goals for the car and what type of power do you want to make? You shouldn't consider a heads swap until you understand TBI chip tuning as well as proper parts selection (X cam with X heads with X tuning with X intake ect ect.)
Old Jul 30, 2006 | 08:53 PM
Car: 1988 Camaro
Axle/Gears: 2:73's
well, ive done the fuel pressure thing, have lifted the TBI unit as well as the injectors, added open air element, Cat delete (for now).. I want headers but theres so many and i dunno. ive checked out the exhaust forum, and everyone has a diffrent set.. so its hard to figure out what i want for that.. right now i have the stock l05 Exhaust hooked to the 350. I have a super turbo muffler, Sounds great through all RPMS, its got a Deep low tone.. its not loud but not like your 2005 chevy pickup exhaust.. (which sucks).
Cam.. i dunno whats in it, the prev owner rebuilt the engine.. I got his phone number.. i should call him sometime..
What i want... all my power, Torque and hp, is way low, i can hit 85 just resting my foot on the throttle about 1/32 of throttle.. I get 25mpg right now thats city and highway combined cruising at 55, and when i say city i mean stop and go and stop and wait and go.. Maybe i should add short flow headers and leave it alone?
however when the throttle it Wide open theres not much there, same way at half.. i have a 2200 Stall convertor i dunno where to start, or if i even should.. I hate seeing the newer 1994 Camaros 100% stock running faster and quiker than me.. but maybe i should keep the 25mpg..?
Old Jul 30, 2006 | 09:00 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
This is my L05 in my 5,500 lbs van. Ported swirl ports, 8.75:1 compression, L03/L05 Peanut roller cam.
YouTube - Chevy Van 350 1
YouTube - Chevy Van 350 2
https://www.thirdgen.org/forums/tbi/...ly-update.html
db057
Apr 28, 2019 07:45 AM
69GTOby
Apr 18, 2016 02:34 PM
mrestrictrplate
Sep 21, 2015 11:24 AM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
