problem
Old Aug 1, 2006 | 12:41 PM
fearfactory17's Avatar
Car: 1989 Pontiac Firebird
Engine: 2.8L V6
Transmission: auto
problem
i just rebuilt my 2.8 TBI and im having a couple problems.
after driving for a while my temp light comes on, but im not overheating and my coolant levels are fine
usually right after this the car will not start, im getting spark, but my fuel injectors arent pulsating. fuel injected vehicles cant have vapor lock right? and its a brand new fuel pump and im getting plenty of pressure.
will a bad coolant temp sensor cut off fuel if it thinks the engine is too hot?
sometimes my starter will just click, but usually cranks right after, the starters been recently replaced.
my fuel injectors just arent spraying fuel, once it sits for about an hour, fires right up with no problem, no hesitation and idles smoothly
new 02 sensor
new coil
new control module
new computer
new distributor
new plugs/wires
new fuel pump/lines
Old Aug 2, 2006 | 06:56 PM
Engine: 2.8L V6
Transmission: auto
i really wish someone could help me, ive posted twice and used the search and have found nothing that helps me.
Old Aug 2, 2006 | 07:41 PM
Toxinz's Avatar
Car: 92 camaro
Engine: 355
Sounds to me like you have a wiring problem somewhere. You might want to go over all of the wires to make sure nothing got snagged up while you put the motor back in etc.
Old Aug 2, 2006 | 08:05 PM
Engine: 2.8L V6
Transmission: auto
i just pulled two codes from the ecm
EST bypass circuit is open or grounded
map sensor
so i guess my coolant temp sensor isnt bad. im gonna check for grounded wires and get a new map sensor tommorow
would either of these be my starting problem?
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
