stock chip with a cam?
Old Aug 6, 2006 | 01:55 PM
tippmann243's Avatar
Car: 89 s10 blazer
Engine: build 4.3
Transmission: t56 6 speed
Axle/Gears: 4.56's
hey guys ive got a couple question. im building a motor for my 1993 gmc sonoma. its a 4.3 tbi with heads and cam. the cam specs are lift I .479 Lift E .488 duration I .210 Duration E .214 LSA 112.
the problem im running into is in 1993 gm gave the 4.3 5 speed s-sereis bastard ecu's (number 16190402) that no one can burn chips for and they incorporated the VSSB, knock module and electronic spark controller into the ecu. so i cant just simply do a ecu swap i would have to do a harness swap.
i was planning on keeping it tbi for a few months so i can finish my mpfi manifold and get some money saved for the mpfi ecu.
i am wondering what kind of idle/drivability probelms im going to have on the stock tune with the new camshaft. i know the system is going to run rich due to the aftermarket cam pulling less vac, and an s-series guy told me to just turn the fuel pressure down to try and lean it out a bit. but im worried about it leaning out up top if i do this. but if i dont mess with the fuel pressure im worried about cylinder wash and flooding.
you guys seem prety knowledgable in the tbi dept so i figured id get your input
thanks
-mark
Old Aug 6, 2006 | 02:14 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The Jeep Barracks - Building an Adjustable MAP Sensor
Before I got into burning my own chips, I built this circuit and used a pair of 350 injectors on my 305 with a head/cam swap and full exhaust.
Old Aug 6, 2006 | 02:29 PM
Car: 89 s10 blazer
Engine: build 4.3
Axle/Gears: 4.56's
thanks for the reply, it looks like that along with an adjustable FPR should get me by till i can ge the mpfi done
thnaks a milion
-mark
Old Aug 9, 2006 | 12:53 AM
Car: 89 s10 blazer
Engine: build 4.3
Axle/Gears: 4.56's
anyone else have input?
Old Aug 10, 2006 | 12:22 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
What does it look like? What do its connectors look like? (pics would help) The solution might be as simple as using a different, more commonly used mask (thing thats programmed on the chip) if its a standard truck PCM.
Old Aug 11, 2006 | 11:02 AM
Car: 89 s10 blazer
Engine: build 4.3
Axle/Gears: 4.56's
its a 3 plug ecu 2 32 pin plugs and a 24 pin plug
italiano67
Dec 11, 2016 09:21 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
Exxon Limited
Aug 9, 2015 08:13 PM
