change to 55lb/hr injectors worth it?
Old Oct 9, 2006 | 03:56 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
im running the stock injectors(flow matched tho), 40lb/hr at 15 psi with a walbro 190 on a 305................would i notice anything if i put in a set of 55lb/hr truck injectors?
Old Oct 9, 2006 | 09:24 PM
91RockS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI (L03)
Axle/Gears: 3.73 Truetrac posi
IMO, unless you are DIY tuning, you will probably do more harm than good because the ECM won't know you've increased the size of the injectors. The injector constant needs to be changed if you go to bigger injectors. 55# injectors would help if you are fuel limited with the stock injectors. You could push your current injectors up to ~20 psi to get more fuel, but again without tuning and datalogging, its hit or miss.
Old Oct 9, 2006 | 11:07 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I've got GREAT NEWS, the stock 305 injectors (green/white) ARE 55 lb/hr.
Old Oct 10, 2006 | 04:23 PM
wasp's Avatar
is that right? huh, ok then, btw, im using a fpr from turbo city, cant get it to go any higher than 15...............maybe 15.5 sonmetimes as i have a fp gauge on dash
Old Oct 10, 2006 | 04:38 PM
Casey Butt's Avatar
Car: 1988 IROC-Z TBI
Engine: L04.3 = 305-310-336
Transmission: TH-700R4
Axle/Gears: 10-bolt, 3.42 posi
That's most likely because of the weak stock fuel pump, not the fpr.
The 40 lbs/hr injectors are from the V-6 TBIs.
Old Oct 10, 2006 | 08:34 PM
wasp's Avatar
if youd reread above, im using a walbro 190
Old Oct 10, 2006 | 10:14 PM
Casey Butt's Avatar
...missed that
jklein337
Sep 19, 2018 06:23 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
86IROC112
Aug 21, 2015 07:20 PM
355tpipickup
Aug 19, 2015 10:02 PM
