car running too hot?
Old Oct 22, 2006 | 05:05 PM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
Hey guys just recently changed plugs,wires,cap and rotor just some normal AC delco plugs anyway my car usually stayed at 220 on the guage after i changed the plugs it started to go passed 220 in town or at a slow speed. i changed the thermostat to a 180 (had a 195 in it) and it runs real cool on the highway (160-180) but today when i was in town or drivin around my neighborhood after driving about 75 miles on the highway it started to warm up again 220+ not to the red yet but still kinda worries me. should i be concerned? or any suggestions would be awsome. thanks guys.
Old Oct 22, 2006 | 09:23 PM
deadtrend1's Avatar
not to worry, yet. The cooling fan wont come on until the temperature reaches somewhere 230ish. Someone will correct me here cause I can't remember exactly. If temperature went over that, and the fans didnt come on then it would be a problem.
Best way to solve your problem if you do a lot of sity driving would be to put a manual switch in the car so you can turn the fan off and on at will......
Or a lower temp hypertec fan switch can help
To elborate more, the low temp thermostat would not prevent it from getting hotter during slow city driving. It will allow the coolant to start to run through the engine at a lower temperature. And when driving on the highway, the car will run at 180 degress now instead of 195.
Is your air damn under the car is good condition, by the way?
Old Oct 22, 2006 | 09:27 PM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
how would i go about doing that. im still pretty green when it comes to mods and what not.
Old Oct 23, 2006 | 06:25 PM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
The hypertech fan switch would screw into the side of the block where the existing fan switch is. Not that tough of a job. That'd probably be your best bet. Direct replacement if I'm not mistaken.
Old Oct 23, 2006 | 06:54 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Yeah, it will screw right into the block but you are going to have to rig the connection as the connector will not likely match the stock one if it is still in good shape. All in all, not a huge deal to do except that getting to that switch on the block is a royal PITA. Expect to top off your coolant after the fact and WEAR GLASSES!
If you get the new fan switch and a lower t-stat, life should be peachy. Don't go too low on the stat though. You want the car to get out of closed loop for efficent operation.
Old Oct 23, 2006 | 07:31 PM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
i have a 180 in it now. i was lookin at those switches. what temp switch should i get with my 180 thermostat
(gonna check that air dam right now)
just checked the air dam its fine.
(also found out i need to replace every damn bushing in my front end)
Old Oct 23, 2006 | 07:38 PM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
Hypertech has a cool fan switch that I have installed that kicks the fan on at about 170. Just go to their site and if I remember correctly, they only have 2 available. I used the advice on this forum to get mine. Once I installed it, no more overheating problems.
BTW, I left my T-stat at stock specs and just used the new switch to kick the fan on at a lower temp.
Old Oct 23, 2006 | 07:44 PM
RSL03's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock
yep just checked summit and they have the hypertech switch for about 48 bucks if i can remember correctly.
Old Oct 24, 2006 | 03:51 PM
DM91RS's Avatar
Car: 91 RS
Painless wiring was the brand that I used in the past. It was cheaper than Hypercrap
theshackle
Mar 5, 2017 06:37 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
86Base
Aug 8, 2015 01:34 PM
