TBI cam
Old Oct 24, 2006 | 09:49 AM
tbiguy's Avatar
Car: '89 Sport 4x4
Engine: 350 baby!
Transmission: 5-speed manny
Axle/Gears: 3.73, open diff. 10-bolt
TBI cam
Was playing around on desktop dyno '03 the other night, looking for a cam that would best suit a TBI 350, with headers/mufflers.
I realize that this program is not entirely accurate, and I have no idea as to what this cam would really be like, but here are the specs of the best I could come up with.
(this is all in seat-to-seat timing, never quite got the .050" timing down right)
Intake / Exhaust
Duration:250 / 270
lobe centerline: 114 / 106
max lift @ valve .480" for both.
cam lobe center angle: 110 (112 is fine as well)
Valve overlap: 40
Ramp rate is set at 3. Not ENTIRELY sure what that means, but it is mild in terms of valvetrain acceleration.
Events:
IVO: 11
IVC: 59
EVO: 61
EVC: 29.
Is there something similar to this, or could one be ground *relatively* cheaply?
Old Oct 24, 2006 | 07:32 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
well depending on what is done to the motor as in compression and cylinder head flow. For a stock or near stock 305 that camshaft would be too big. I have seen most members here recomend and lt1 camshaft which has a duration at .050 of like 204. For a relatively stock 305 i wouldnt run much bigger than that.
Old Oct 25, 2006 | 10:45 AM
tbiguy's Avatar
Car: '89 Sport 4x4
Engine: 350 baby!
Well, I actually have a 350 tbi in my truck... Would it bee too much for it?
Headers would go along with this cam, but otherwise leaving the heads and intake untouched. Stock engine, I do not even know if the block has the roller cam lifter retention spider bosses. It may have the bosses, but I will bet $50 they are not tapped. This is a 350 tbi out of a '93 suburban...
Old Oct 25, 2006 | 12:05 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
This would be a rather mild cam. 250/270 would probably end up somewhere around 206/218 @ .050 for a hydraulic flat tappet cam which is what I believe should be in a 93 350 truck engine. I would call one of the major cam vendors and price a custom grind and ask for their suggestion of stock grinds to suit your requirements.
Old Oct 25, 2006 | 08:06 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
350 tbi truck motors have the nipples in the blcok for the roller but are not tapped, you can tap them tho. I would look into one of crane emissions cam for computer controlled vehicles in there.
Old Oct 25, 2006 | 08:37 PM
tbiguy's Avatar
Car: '89 Sport 4x4
Engine: 350 baby!
*snicker* Emissions.
I do not actually have specs on the stock cam... I think this one is mild but would show an improvement...
Thanks.
I did come up with some .050" timing. Duration there was 200/240 IIRC.
Was wondering if it would be worth messing around with or if an off the shelfer would be best...
On DD'03, this cam with headers/exhaust was making 375 ish lb/ft from 2K all the way to 4000K, and falls to 350 lb/ft at 4500rpms. I realize this is optimistic, but it should still be a bit better than stock.
I'd hate to give up too much torque below 2500, as it is still a truck. Just wanting to make a bit more torque for a bit longer, say close to 5000 or 5500 rpms.
MustangBeater20
Oct 29, 2022 09:20 PM
junkcltr
Aug 2, 2019 11:12 PM
509 camaro fan
Sep 6, 2015 10:43 AM
z28addict8490
Sep 5, 2015 03:56 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
