hesitation?
Old Nov 2, 2006 | 02:09 AM
Kandied91z's Avatar
hesitation?
just picked up a 91 rs 305 tbi and it has some hesitation under load. prime example is to ease into the gas with the bake on. the motor breaks up a bit.
what are some key things to look into on this?
Old Nov 2, 2006 | 02:54 AM
Firechicken92's Avatar
Is the gas old or maybe have some water in it.
Check the timing.
Just some suggestions. Matt
Old Nov 2, 2006 | 02:31 PM
Kandied91z's Avatar
gas is fresh, no leaks and new fuel fitler as well. have not replaced the pump but it's a low pressure system so i would assume the pump is fine since it does start up and drive ok. timing is a few degrees advanced 2 or 3 at most.
Old Nov 2, 2006 | 10:28 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
I dont know, but I think my throttle shafts are worn out on my car and it whistles and idles high for a while before idling down. This happens at every stoplight. At about between 2000-2500 rpm it hesitates in each gear and I guess what I am leading to is a vacuum leak could be a prob.
Old Nov 2, 2006 | 10:52 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Unplug the two wire electrical connector from the EGR solenoid. Now take it out and drive it around. I am willing to bet your hesitation disappears. You might even be able to duplicate the feel right now by raising the RPM up to about 1200-1500 in Park/Neutral, after several seconds it will start missing heavily. The cause is typically a bad EGR valve, well not so much bad, but the bypass passage becomes plugged with carbon. The passage is so small going up through the valves stem that it is almost if not impossible to clean. When the passageway clogs, the valve is now pulled open much too soon. Another way to test that the valve is working properly is to start the car, let it warm up, then feel the backside of the valve as you bring the engine up to a constant 2,500 rpm or so. You should feel the diaphram start rapidly cycling up and down as it "meters" the exhaust gases to the intake. When the passageway becomes clogged the valve will simply pull all the way open and cause the bog.
Old Nov 3, 2006 | 12:49 PM
Kandied91z's Avatar
i know mine seems to do this more once it's warmed up..?
Old Nov 4, 2006 | 02:03 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Could be a bad 02 sensor. They often go bad and do not throw a code. This would explain a hesitation when in closed loop.
Old Nov 13, 2006 | 02:14 PM
ahusted's Avatar
THANKS FAST!!!!!!! My old mans 5.7 truck did this right after he bought it. It baffled me because the valve moved freely and everything looked good visually. I just plugged it because he doesn't drive it much and I didn't want to spend money on something that might not fix it. It turns the SES light on at cruise and freaks him out, eventhough we know the cause. He will be very happy with an easy fix.
Old Nov 15, 2006 | 10:52 AM
3rd-gen junkie's Avatar
Car: 1991 Camaro RS
Engine: L03 5.0L
Axle/Gears: 3.08
I have a '91 TBI L03 and it has vacuum only going to EGR, is there some way else I can test that to see if it's the problem. Also, any ideas regarding how to isolate an intermittent vacuum leak? I have something funky going on under there but have no clue what's happening. All started with the new EGR, but I suppose it's working becasue the EGR stopped throwing a code... 'bout ready to say f*%$ TBI and slap a carb on there!
Old Nov 15, 2006 | 12:46 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
So many things... Faulty/worn spark plugs, bad ignition, low fuel pressure... Have you done a tune-up yet?
Old May 14, 2007 | 08:32 PM
82 recarooo's Avatar
Re: hesitation?
throttle shaft bushings wear out after 50,000 causing a vacume leak and unsteady idle. have them serviced
Old May 14, 2007 | 10:11 PM
Kandied91z's Avatar
Re: hesitation?
never heard of these before. where are they located, couldn't i just replace them myself or is it something i have to have rebuilt?
Old May 14, 2007 | 10:25 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Re: hesitation?
Teh throttle shaft wears into the TBI housing. The main problems it causes is a throttle that sticks open. The only cure is to have the TBI housing bushed, which requires machining.
Old May 14, 2007 | 11:54 PM
Kandied91z's Avatar
Re: hesitation?
ah... i see.
i'll have to look into that.
Old May 15, 2007 | 06:47 AM
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
Re: hesitation?
had exact same problem.... TIMING! Check base timing!!
Old May 16, 2007 | 03:43 AM
Kandied91z's Avatar
Re: hesitation?
been there, did that... unfortunately. thanks though!
Fanatic1074
Oct 3, 2022 05:57 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
