Leaking gas :(
Old Sep 18, 2000 | 06:24 PM
Pro Tour RS's Avatar
Leaking gas :(
Why am I leaking gas from the shaft that controls the Throttle Position Sensor? Its a little leak thats coming from around the spring on the shaft. Its running down the side of my manifold. What kinda seal is it "O" ring or somthing?
Old Sep 18, 2000 | 10:13 PM
BK's Avatar
BK
I am only guessing here, but what I am thinking is that the throttle shaft that goes across the TBI to the accelerator linkage may have worn a hole in the TBI where the shaft pivots at the TPS unit. I'm not sure if this helps or not. Good Luck.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
dbrochard
Oct 3, 2015 12:43 PM
TBRays98
Sep 6, 2015 05:05 PM
tgp1990
Sep 4, 2015 06:24 AM
