No Balls!
Old Sep 14, 2000 | 07:16 PM
92RSCAMARO's Avatar
No *****!
Even with this engine should I expect my car to run only a little bit faster than it used to even though I have an engine with the potential of 350+ horse.I am using the stock TBI and stock computer.Is this lack of power to be expected?I am just running it with the stock TBI while I get it broke in.
Old Sep 14, 2000 | 07:17 PM
92RSCAMARO's Avatar
gees i forgot my sig again
Chevy 355 cid chevy orange and lots of chrome
Vortec heads ported polished and milled also the exhaust ports are ported.
Edelbrock #7116 performer RPM intake also ported to match heads.
Keith black 12cc 9-6-1 compression flat top pistons.
Comp cams extreme energy #262 roller cam.
Pro jection 1 inch tbi adapter.
14 x 2 open air element (couldnt close hood)
Accel 8mm superstock wires.
Old Sep 14, 2000 | 07:50 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Dude, u can't run an engine like that with STOCK TBI! U need to get a holley 670cfm tb unit and u need to get a custom prom made or atleast go out to the junkyard and find a 350 prom from a formula or somethin to hold u off until u get a custom one built. Ur engine will run REAL ****ty if u keep that stock TBI unit and stock prom.
Eric Natzke
91 Firebird 305 TBI (dropping in a 355 summer of "01")
-Edelbrock TES Headers (coated)
-P265/50/R15 tires
-MSD 8.5mm superconducters
-TBI Spacer
-Accel Cap & rotor
-160 Thermostat
Hypertech Thermomaster
-TransGo ShiftKit
-B&M Supercooler 28,000 GVW
-March pulleys
Custom 3" exaust (not cat)
flowmaster 80 series -Smog pump and AIR pulled
-Edelbrock Strut Tower Brace
-3:42 GM Motive
-Auburn Posi Unit
-K&N open element
http://hometown.aol.com/J007Golden/index2.html
Old Sep 14, 2000 | 08:36 PM
92RSCAMARO's Avatar
I figured that.So I need to get the 670 which I already have the adapter for and then drive it to this guys place called pauls high performance and have him burn a chip for me?will this be enough to make the engine run at full potential?
Old Sep 15, 2000 | 12:40 AM
Rock90rs's Avatar
Car: 92 RS/90' vette
Engine: Heads/cam/miniram/blah blah blah..
Transmission: T5/700!
Axle/Gears: 3.08
No such thing my friend.
92RSCAMARO,
Like 91BIRD305 said the 670 and the prom are a must. have a custom prom burned. Only then will it reach its full potential.
Old Sep 15, 2000 | 03:18 AM
Dan W's Avatar
Here is why you have a lack of power:
The new motor with proper fuel, air and spark will make (350 hp you said?)
So you re-install the same TBI and distributor that was designed for the fuel and air requirements of a 180 or so HP 305... That extra power that the 355 makes if from its ability to pull in extra air (and use the extra gas that goes along with it) Youve choked it with that tiny stock 305 TBI unit.
To supply that 350 with the air it needs... a 2" bore unit from a big block truck would be my first choice, if not available, then the Holley unit. Either of these will come with injectors that will work... 85# ish... make sure you dont get the 65# injectors that can come in the holley 670, they are not enough to feed 350hp. Now, you have the air and fuel CAPACITY, you need a chip that will properly send the correct amount of fuel and adjust the spark properly. I suggest you go to the prom board and ask questions about that portion. You do need a custom chip if you want it to run right. If you install an aftermarket TBI w/o the chip, you will be way rich at Idle or way lean at WOT depending on how much FP you run.
Old Sep 16, 2000 | 12:09 PM
92RSCAMARO's Avatar
I will definately try to do that when I get the money.But I achieved my goal of beating my friends 91 mustang gt auto with full exhaust!and the timing is retarded also.he wont even be in my mirror when it is running right.
Old Sep 16, 2000 | 12:25 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
not to rain on your parade but auto mustangs arent known to be particularly fast and I agree with dan
Old Sep 16, 2000 | 07:14 PM
92RSCAMARO's Avatar
I just think that it is funny because my car stalls if I put it to the floor and I beat his as*.My friends friend that I dont know to well has a 89 blue mustang gt 5 speed with a full exhaust and cobra intake that I can beat also.I know this because I was in my friends 91 when we raced him and I beat him worse than what he did.I just cant wait to see how it will run with the timing right a chip and a 670.
Old Sep 17, 2000 | 08:46 PM
92RSCAMARO's Avatar
I know I need a 670 with 85lb injectors and a chip. but what is the deal with the fuel pump?I think I heard that it will only handle like 320 horse or something.So what do you guys think I should do about a fuel pump for my application,like what one?
Old Sep 19, 2000 | 03:06 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
I would get an Edelbrock Fuel Pump or somethin. As for the formula chip, I just was guessing on that, I figured he would get the clue and maybe get a hold of a 350 chip until he gets one burned. If I were u I would get the aftermarket fuel pump,custom prom,Holley TB unit and get 85lb injectors,MSD Distributor,maybe even a MSD HEI Coil and get some MSD Superconducters. I like mine and if you go MSD Dist. then u might as well go with everything else MSD. U know?
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
