who did this?
Old Sep 27, 2000 | 07:43 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
who did this?
Someone on here did this to their TBI 305:
Corvette Cyl heads
1.6 rocker arms
intake- I think
Anyone know who this is ?
88 IROC the best RS ever made!
well except for the BC4s
Old Sep 27, 2000 | 07:45 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Nope
Eric Natzke
91 Firebird 305 TBI (dropping in a 355 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-Accel Cap & Rotor
-Rapidfire Plugs-Pablo's Free Mods-265/50/R15 Tires-Emmison's all Gone
http://hometown.aol.com/J007Golden/index2.html
Old Sep 27, 2000 | 11:08 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
That was probably me...
I just recently finished installing a set of ported Aluminum L98 heads, Torker II intake, 670cfm throttle body, 1.6 roller rockers...I think that's about it...
It's not running right and I'm working on burning my own chips to fix the problem, but much to my disgust my programmer I ordered was defective. I'm currently waiting on a new one.
-Mark W.
<A HREF="http://www.angelfire.com/al3/thegreycar">'88 SC Camaro w/ 305 TBI</A>
Old Sep 28, 2000 | 12:10 AM
Tas's Avatar
Tas
vortec heads are better than stock L98 heads. FYI
https://www.thirdgen.org/messageforu...ML/000089.html
AOL IM: superGRtaz
ICQ: 82881207
Old Sep 28, 2000 | 12:31 AM
Mark305TBI's Avatar
Well, they are and they aren't at the same time.
The Vortec heads are cast iron and the Vette heads are aluminum--advantage vette.
The Vortec heads flow more air than the Vette heads (but not alot)--advantage Vortec.
The Vette heads have 58cc combustion chambers the Vortecs have 64cc, this is completely application specific--no advantage.
Vette valve-springs will take .500-.550, depending on year, the Vortecs will take .450--advantage Vette.
Vette heads use the standard carbeurated intake bolt pattern, Vortecs use Vortec specific bolt pattern--advantage Vette.
Vortec heads are $420/set Vette heads are $770/set--advantage Vortec.
-Mark W.
[This message has been edited by Mark305TBI (edited September 27, 2000).]
Old Sep 28, 2000 | 11:05 AM
avro206's Avatar
Car: 89 Formula
Thanks Mark. Thought you had a nice car and am interested in following your build up as
I might take some ideas from your project.
Old Sep 28, 2000 | 11:13 AM
Mark305TBI's Avatar
No...thank you . I got in touch with the programmer people and my programmer should be here tomorrow. I'll get it running right, throw the G-Tech at it, and post some times on here so anyone who's interested can see what it's worth.
Thought of another Vette advantage, Vette's have screw in rocker studs, Vortec's have pressed in studs...
-Mark W.
Old Sep 28, 2000 | 11:21 AM
Scott C's Avatar
I had ported Vette heads, Crane Compucam, Edelbrock 2101 carb intake, TBI adapter, Holley 670TBI, 1.6 roller tip rockers, headers, 3" catback, Centerforce clutch, 3.73 posi and MSD/Accel ignition on my last '92 RS 305.
After going through a few "custom" chips, it finally ran "well". It always ran rich no matter what I did. With all of the mods, the car really hauled A-S-S! I never timed it, but it had to be in the high 13-low 14 second range. It spun up to 6,000rpms all day and could smoke the tires through 1st & 2nd.
With the huge amount of cash I spent on the 305 and the year of tuning it took to get it right, I have decided to go a different route with my new RS as my sig indicates:
'92 RS, ZZ4 10:1 350, Edelbrock 6085 heads, Crane 208/214 467/482 cam, GM/LT4 1.6 true roller rockers, Holley Projection TBI intake, Holley 670 TBI, SLP/Jet-Hot 1-5/8" headers, Catco 3" cat, Flowmaster 3" catback, Hughes 2500 stall converter, stock 700R4, Auburn Pro posi w/3.42, 17x9" SS rims w/BFG tires, Medium Quasar Blue w/white SS stripes, 48,000 miles....
Old Sep 28, 2000 | 12:16 PM
Mark305TBI's Avatar
Yeah, eventually I plan on putting a bigger short block under my heads and stuff. I might put a cam into the 305 before I replace the block, I haven't decided yet. I've got this uncontrollable urge to see what I can get out of the 305.
On the short block issue, I'm having trouble deciding between a 383 and a 355, and pre-87 or post-87 engine block (I've already got the pre-87 here at the house, but used blocks are cheap).
-Mark W.
