Cam suggestions...
Old Sep 29, 2000 | 12:36 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Cam suggestions...
Which of these cams would you recommend for my set-up (other suggestions welcome). I've got a set of ported L98 aluminum heads, Torker II intake, 670cfm throttle body, and 1.6 roller rockers. I think that's all that's gonna make a difference, see my website if ya' wanna know more...
<A HREF="http://www.cranecams.com/master/apps/chevy37.htm#6. CompuCam">Crane CompuCam 2032</A>
Duration @.050: 214/220
Lift:.452"/.465 (I'm not sure with what rocker ratio)
<A HREF="http://www.cranecams.com/master/apps/chevy38.htm#2. PowerMax">Crane PowerMax 109821</A>
Duration @ .050: 214/222
Lift:.488"/.509" (not sure on ratio here either)
<A HREF="http://www.cranecams.com/master/apps/chevy38.htm#3. PowerMax">Crane PowerMax 109831</A>
Duration @ .050: 222/230
Lift:.509"/.528" (again, I'm not sure on ratio)
Production LT4 cam
Duration @ .050: 203/210
Lift:.476"/.480" (with my 1.6 rockers)
LT4 Hot Cam
Duration @ .050: 218/228
Lift:.525/.525 (with my 1.6 rockers)
-Mark W.
<A HREF="http://www.angelfire.com/al3/thegreycar">'88 SC Camaro w/ 305 TBI</A>
Old Sep 29, 2000 | 09:12 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Well first off, what kind of mods do u have? Do u have headers? If you have a completely stock car then I would wait on the cam. I would do exaust, headers, some intake work like open elemet, spacer, some tb unit modifying and then I would get the cam. You would get way more power out of your cam if you do it like this.
Eric Natzke
91 Firebird 305 TBI (dropping in a 355 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-Accel Cap & Rotor
-Rapidfire Plugs-Pablo's Free Mods-265/50/R15 Tires-Emmison's all Gone
http://hometown.aol.com/J007Golden/index2.html
Old Sep 29, 2000 | 11:27 AM
Mark305TBI's Avatar
headers, cat-back (no cat), 3.73 gears, positraction, heads, intake, 2" throttle body, little stuff (pulleys, ignition, ect.).
-Mark W.
Old Oct 4, 2000 | 10:02 AM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
I'll tell you, I wish i would have gone with a little longer duration on my cam. You can check it out at the bpottome of the page. I don't think I would go more than .510 max lift on either one. All those raitos that you listed are for 1.5 rockers. If you want my opinion you shgould look for someting like .488/.510 x 224/230 @.050" You'll definatley need a custom chip with that Cam a 2800 stall TC would work really well. Since you have and intake and Headers already then you are definately hurting yourself with that dang peanut cam! Also try to keep the Lobe separation less than 112* that will keep you idle descent. If you don't have time to get a custom chip during all this, your car will run but tou;ll need to turn the fuel pressure way down. Other wise ytou will be running REALLY rich. (been there done that, got the T-shirt to prove it ). If you have questions Please Email me and I'll be happy to discuss my experience with you.
later,
Lars
'92 RS 305 TBI
K&N Open Element
Ultimate TBI mod's (thanks Pablo)
Cam[.442"/.465" x 218*/224* @ .050", 10:1 Hypereutectic Pistons
Performer Manifold
Shift Kit, Corvette servo,
and 2800 Stall Trans Specialties Converter,
Gutted Cat, IAT Resistor
MSD Blaster Coil, Accel Cap and Rotor
Old Oct 4, 2000 | 02:02 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Lars meant a wider lobe sep is better, like above 112
i really like the LT4 hot cam myself. What with it being roller i think it would make the same power as a bigger flat tappet cam and easier to program for
btw Lars, lose the IAT resistor, thats just making you richer
Old Oct 4, 2000 | 05:29 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
E-mail Coolfb@aol.com He put a real nice cam in his 305 tbi and he has never had a problem with it at all.
Personal Note: The guy runs a 14.73 in the 1/4 mile with a 305 tbi, now that is badass!
Eric Natzke
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
