Air Cleaner Question?
im buying a new air cleaner i was wondering if anyone knows offhand how much taller of an air cleaner will fit under the stock hood of an RS with a stock intake and throttle body
Car: '00 Chevrolet Corvette
You can get a 14"x3" element under it. If you get a drop-base cleaner you'll have to keep the spacer ring. If you get a non-drop base you'll have to throw it away. Get a non-drop.
-Mark W.
'88 SC Camaro w/ 305 TBI
-Mark W.
Mark that's only half true. If you have no plans on getting/making a TBI Spacer then a non-drop base with a 3" filter is your limit. But if you use a 3/4" TBI Spacer you can use a drop base (without using that POS gold ring) and a 4" filter. Eitherway will be more then enough air.
1989 Camaro RS LO3 WCT5 "The Hose Queen" 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
ICQ: 61342629 AOL IM: BlackSunshineZ28
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
