Engine swap
Old Oct 9, 2000 | 10:20 PM
camaroracer1992's Avatar
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
Engine swap
I have a lo3 motor and I plan on swapping the following:350 4 bolt,forged crank,pink rods,crane compucam,and keep my tbi setup with a custom chip. My question is I would like to put a Crane Compu Cam in the motor that is for a carb car because the cam has a higher lift, and slightly longer duration (LSA 112). If i get a custom chip burned will I be able to use a compu cam for a carb with my TBI?
Old Oct 10, 2000 | 12:16 AM
SCOTTCAMARO1's Avatar
as long as you use a custom chip you shouldnt have any problems (what intake and heads are you useing?)
Old Oct 10, 2000 | 04:23 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
yep scott is right
and what sort of cam and heads are you planning on that need such a strong bottom end?
Old Oct 11, 2000 | 07:53 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
TBI is good for our kinda engines. But personally, if I went something over 350hp I would go with carb. I mean, you don't see today's cars with TBI still on them do u? And no one better bring up anything about trucks with TBI because I don't care. We have firebirds, not 454 Trucks. So if I was you, and you think your 350 is going to be putting out big numbers, save yourself the money and time espically and convert to a 650cfm or whatever cfm carb and just do the swap. Cause with TBI you never know how things are going to run. With carb you will after the tuning cause if thats what the company that made the engine dynoed it with then that must be the best injection system for that engine. Makes sense to me.
Eric Natzke
91 Firebird 305 TBI (dropping in a ZZ4 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-Accel Cap & Rotor
-Rapidfire Plugs-Pablo's Free Mods-265/50/R15 Tires-Emmison's all Gone
http://hometown.aol.com/J007Golden/index2.html
[This message has been edited by 91Bird305 (edited October 11, 2000).]
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
