wiring in my Holley 670 tbi
Guest
Posts: n/a
i have a problem. the injector harness on my car is totaly different then the wiring ont the holley unit. what are you guys doing to get the holley unit to work on your car.
92 Camaro RS
305 tbi
5-speed, Hurst shifter
stock heads
open element
k&n filter
accel 8mm wires
bosch platinum plugs
headman hedders & y-pipe
hooker maxflow muffler
gutted cat
hypertech prom
posi 3.42
92 Camaro RS
305 tbi
stock heads
open element
k&n filter
accel 8mm wires
gutted cat
hypertech prom
posi 3.42
Car: '00 Chevrolet Corvette
They give you a connector to splice into the injector wiring. Don't follow Holley's instructions on how to wire it up, they're wrong. Wire 'em up with the colors matching.
-Mark W.
'88 SC Camaro w/ 305 TBI
-Mark W.
Guest
Posts: n/a
that would work but i didn't get the connector you are talking about. can you give me a part #. thanks
92 Camaro RS
305 tbi
stock heads
open element
k&n filter
accel 8mm wires
gutted cat
hypertech prom
posi 3.42
92 Camaro RS
305 tbi
stock heads
open element
k&n filter
accel 8mm wires
gutted cat
hypertech prom
posi 3.42
remember, that unless you have custom chip tuning done your car will run extremely rich with those injectors since they are 65 lb units and your stock injectors are ~45 lb units. you might want to consider using your stock injector pod
Guest
Posts: n/a
Thanks for the info pablo i might consider, but you still didn't answer my question of how to wire in the holley unit.
92 Camaro RS
305 tbi
stock heads
open element
k&n filter
accel 8mm wires
gutted cat
hypertech prom
posi 3.42
holley Pro-jection intake
crane 2030 cam
92 Camaro RS
305 tbi
stock heads
open element
k&n filter
accel 8mm wires
gutted cat
hypertech prom
posi 3.42
crane 2030 cam
E-Mail Holley. I'm not sure if they sell that part seperate or just with the throttle bodies. You'll have to ask them. Beware, however, their on-line tech support is pretty bad... You might have to call 'em.
-Mark W.
-Mark W.
Dialed_In
Aug 20, 2015 01:45 PM
