TBI & Fuel pressure regulators
Old Nov 15, 2006 | 01:59 AM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
At the moment, there's a couple of active threads that deal
with fuel pressure regulation for TBI's, but I haven't yet seen
any responses that will help me out, or that might even go in
the direction I'm interested. So for the master Yoda's out there...
Project data:
-- A 350 modified enough (cam, heads, headers, etc) to justify
700 - 750 cfm induction.
-- Cost-benefit analysis -> keep the TBI control system intact
but upgade as necessary, such as:
- ECM upgrade from RBob, & custom tuning
- TBI modification to support the cfm requirement above.
The original TBI unit has a static pressure regulator, which can
be upgraded to a variable one. But there doesn't seem to be a
way to accurately measure the pressure at the injectors.
For maximum tuning of these units, how useful is it to know this???
Assuming it is useful, what about removing/disabling the built-in regulator,
and adding an external one to facilitate precise pressure measurement?
thanks,
kk
Old Nov 15, 2006 | 02:47 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
what the fuel pressure is set at is a need to know item.
you can get a fuel pressure gage kit that will allow you to mount an adapter where the fuel filter goes at & tie the pressure gage into the adapter. you would only have this hooked up when you are making a change to the fuel pressure.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
89-S-dime
Aug 12, 2015 11:57 AM
