Engine running very bad.
Old Oct 20, 2000 | 12:39 PM
seanjordan's Avatar
My engine is running horribly. It is idling very bad, and backfires when I rev it up. This started happening imediately after I put an open element air cleaner on it. When I was taking the old air cleaner housing off of the TBI unit, I was really rough getting the IAT sensor out of it. I've checked all of the vacuum lines, and havent found a leak.
I know it's not the EGR valve, because I recently installed a new one. I think that it could be the IAT sensor, because while the engine was running, I took it off to see if that would change the idle any. Absolutely nothing happened when I did that. In the past I have had it disconnected and the engine ran badly. Could this be the problem, or should I look into something else?
Any help is appreciated,
Sean
Old Oct 20, 2000 | 01:48 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
sounds to me like youve already figured it out. at least where to start. get a new one and if it doesnt work, take it back.
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
