NonDrop base air cleaners?
Old Oct 20, 2000 | 01:19 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
If I got one instead of my 14x3 drop base, and took out the aircleaner spacer ring. I could stack another air filter on top of the one I already got, and have another 80+ square inches of air flow right?
Advantage? or big freakin deal?
Assume I dont have a stock 305, just for arguements sake, say I have beast motor.
More air = Better? or will i disrupt flow by etc..
My intake is my first step to making power, I know gears are great...etc.. but Im not asking about other stuff.
I just want to know, in the long run, should I maximize/increase my air cleaner area. Or is my 14x3 K&N already capable of flowing more than enough to my 454 tbi. Assuming the engine was pulling as much air as the tbi could flow, 670 whatever...
Bottom line, what does a 14x3 k&n flow and how much flow would I gain by stacking another 2 inches of aircleaner on top of it.
ENGINE SPECS:
305 TBI,Open Element,K&N 14x3,Hypertech Stage I,160 Deg. Thermostat,454 GM TBI
STEREO SPECS:
JVC Kalmeleon kdlx3,Infinity Kappa 2way 6x9's,PPI 4x6 Coaxials,PPI PC2400 AMP @ 2ohm
DEI Studio 12" 4ohm DVC,Custom Box:Exactly 1 Cubic Foot
Old Oct 20, 2000 | 02:10 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Beats me, but I don't think it could hurt u know? Seems like a little more air flow wouldn't hurt nothing and maybe even help. Hey, has anyone seen those extreme air lids by K&N now? Where the lid itself is a filter? Now that is a neat idea.
Eric Natzke
91 Firebird 305 TBI (ZZ4 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-Accel Cap & Rotor
-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://hometown.aol.com/J007Golden/index2.html
Old Oct 20, 2000 | 11:05 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
how could you stack another filter on top? theres no room and the aircleaner stud isnt long enough either
Old Oct 20, 2000 | 12:31 PM
Tas's Avatar
Tas
switching out the drop base and spacer ring for a non drop base and no spacer ring won't change the height. I have a flat base k&n 14x3 air cleaner(no ****ty spacer ring). It was a generic PAW 14x2-1/8 crome one with paper filter for $17. I finally got the k&n last month. I needed a longer stud from PAW too. it all fits under the formula hood and gets nice cold air from the hood being opend. I want to make a sheetmetal pan to seal it. I have about 1/2" to 1/4 inch before I hit the hood so If I want to put in a TBI spacer or change the intake I might have to go for a different filter. I think I can get another 1/4 out if I changed my lid. I noticed the PAW is a little taller than my friends(he kept his stock wingnut stud).
-Tas
'89 Formula WS6
305, TBI, auto, 14x3 chrome flat based open element with K&N, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
ICQ 82881207
Old Oct 20, 2000 | 01:54 PM
snflupigus's Avatar
Well, Pablo, if i drop the base 2 inches, which is about what the spacer ring is, the TOP lid wont change in height at all, if i add a filter that is the same height as the spacer ring, understand now?
Even so, Im more than sure I could make a new stud, or something that worked.
But still, what does a 14x3 k&n flow. does it flow more than 670cfm already, which would be the supposed max flow rate of my tbi, making more filter area worthless, or does it flow less than that, making another 2 inches of filter flow, closer to unrestricted.
Old Oct 20, 2000 | 03:02 PM
Tas's Avatar
Tas
well I had a 2-1/8 tall paper filter before and the 3" tall K&N made a noticeable difference. Both should flow more than my stock TBI needs but there still was an improvement.
Old Oct 20, 2000 | 03:18 PM
snflupigus's Avatar
Note: I dont have a stock TBI.
Its a GM 454.
ENGINE SPECS:
STEREO SPECS:
Old Oct 20, 2000 | 03:50 PM
Tas's Avatar
Tas
on what kind of intake? what car you have? RS? I was trying to explanin that your filter should be in the same location with the flat based air cleaner. because the distance yours drops down(in the center not the outer edge) is countered with the spacer ring. a non drop base one will REALLY unshroud your TBI.
Old Oct 20, 2000 | 06:20 PM
snflupigus's Avatar
its a stock intake, but hopefully if santa thinks i was nice this year, i can go buy one. if you know what i mean.
anyway.
is unshrouding bad? or did you mean good?
you know what. im just gona do it and see what it feels/looks like.
ill take pictures.
post unofficially closed.
ENGINE SPECS:
STEREO SPECS:
Old Oct 20, 2000 | 06:31 PM
Tas's Avatar
Tas
Shrouding is bad. thats why when somone passes out they tell everyone to stay back. if you form a tight circle aound that person then there is a lot less fresh air to breathe. Also when people talk about combustion chambers you try to unshround the valves by countouring the walls of the combustion chamber so air doesnt need to make a 90* turn down when the valve opens.
[This message has been edited by Tas (edited October 20, 2000).]
Old Oct 20, 2000 | 08:39 PM
snflupigus's Avatar
he he, so unshrouding, would be backing up those people, so that instead of having a 6" inch tight group that air cant get through you have a loose 14" group of people that air can get through.
hey i get it now.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
