filter question
Old Oct 24, 2000 | 05:07 PM
RedCamaroRS's Avatar
filter question
Hey guys, quick question. Which filter would flow more air on my open element:
A 2 1/2 inch high K&N filter, or a 3 inch high Fram filter? I have both and was wondering which would be better. Also, I would like to tell you that if you have never adjusted your TV cable, you should definitely do it. I had always felt my tranny shifted sluggishly, and what a difference it made to get it properly adjusted. It's a whole lot more fun to drive.
Red
Old Oct 24, 2000 | 09:42 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
most paper filters flow comparable to what a k&n flows as long as its not one of those really thick ones go with the fram
Old Oct 25, 2000 | 09:13 AM
Get Blown ?'s Avatar
http://www.fordmuscle.com/archives/2...rs/index.shtml
See for yourself.
Personally I think K&Ns are not worth the money.
1989 Camaro RS LO3 WCT5 "The Hose Queen" 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
ICQ: 61342629 AOL IM: BlackSunshineZ28
Old Oct 25, 2000 | 10:46 AM
greearhr's Avatar
Use up the paper one and then try the K&N since you already have both. Then you can compare the differencs. I use K&N in evrything I own.
Bear Tracks
Old Oct 26, 2000 | 06:52 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Hey, K&N came in second in that flow rate thing. Who is Wix?
Old Oct 26, 2000 | 09:49 PM
Wix makes filters for just about anything. The ones that proved better are used in NASCAR. But you too can buy them. Look around the internet. I saw a site not too long ago that sells the same exact Wix filters tested and it is cheaper then K&N by like 15 bucks, however they're not reusable.
Old Oct 29, 2000 | 11:57 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Thanks Blown, i will look into that.
Eric Natzke
91 Firebird 305 TBI (ZZ4 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-Accel Cap & Rotor
-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://members.aol.com/j007golden/91firebird.html
Old Oct 30, 2000 | 12:20 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
15 bucks cheaper, but not reusable? no way in hell. 20 cfm isn't worth that much to me.
-brian
1991 Camaro RS
Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, Edelbrock TES Headers, Edelbrock Victor Series Water Pump, Accell Superstock Wires, Cap, and Rotor, MSD Blaster Coil, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
z28boy@twcny.rr.com IM name: Z28 Boy
Brinkkl2000
Aug 4, 2018 08:29 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Thornburg
Aug 25, 2015 01:46 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
