HELP: TBI Idling weird
Old Oct 25, 2000 | 08:34 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Transmission: 700R-4
Well I havent done anything great to my engine but I have put an open element air filter on it. My idle is real bad. It lobes really bad, if I let off the brake a little bit while stopped it jumps, the rpm is staying the same but it just a constant jumping on each rotation. I have replaced my EGR, Oxygen Sensor, Plugs, Wires, Cap, Rotor and nothing helps does the same thing. I have reset the computer but doesnt change. I have checked for vacuum leaks but didnt find anything, I have also cleaned the Throttle body and Idle Air Control Valve. It still runs the same going down the road, but the idle really sucks. I get no codes. Any body with any suggestions?????
91RS305TBI
Old Oct 26, 2000 | 06:10 AM
SeanSullivan's Avatar
What did you do with the IAT? Did you check it?
Old Oct 26, 2000 | 07:45 AM
TBImaster's Avatar
Dude, this sounds like your TBI gasket got sucked down your intake. Its definitly a vac leak. Look around the base of your TBI. Start the car and get a can of WD-40 and spray some at the base of the TBI. If the idle smooths out you've found your prob.
You can use this trick around the intake also.
Old Oct 26, 2000 | 04:50 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
The IAT : I drilled a hole in the new air cleaner and just put it in like it was in my other one. I unplugged it and the car ran no different and it gave me a code. Thanks I will try the WD 40 trick. I will repost as soon as I try that.
Old Oct 26, 2000 | 06:12 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Well I sprayed WD 40 everywhere and nothing happened (I wished it would have) Is it worth replacing the TBI Gasket if it didnt make a difference with the WD 40. What else is there to try??
91RS305TBI
Old Oct 27, 2000 | 01:51 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
clean the IAC passage with carb cleaner, reset minimum idle, and reset TPS, see if that helps
Old Oct 27, 2000 | 02:27 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
Did the problem start when you put on the open element? or did it just start randomly and you just told us you have an open element as your only mod?
my suggestion would be to replace the iac, after examining if it works or not(see if its moving at all). You can always take it back.
Try reseting before removing and replacing.
Old Oct 27, 2000 | 08:00 AM
FastBroker's Avatar
Could also be intake manifold gasket leak into the lifter valley, but that'd be a heck of a coincidence...
Old Oct 27, 2000 | 01:17 PM
badbird88's Avatar
Als otry plugging the EGR valve vacumn lines and the lines running from the solenoid and see if that clears the idle up. The solenoid could be screwed up allowing the EGR valve to stay open at idle which would give you a crappy idle. This is a quick test and should take no longer than a few minutes.
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
Old Oct 30, 2000 | 07:34 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Well I changed the IAC cleaned the IAC passage real good and checked the TPS and it was giving the right voltage. Havent tried blocking off the EGR yet, ran out of time. Keep the ideas coming though.
THANKS
Old Oct 31, 2000 | 11:48 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Umm check your timing and check to make sure that you put the wires back on in the right spots =)
Just one wire off will screw up the idle and drivability like that..
Kat
90 RS 305 TBI A4
Dumb ***/**** poor/orginating memeber of the infamous NE Crew
Time to see, believe this in me,This pain that i feel deep inside
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
EFR2000
Aug 18, 2015 08:54 PM
92camaroJoe
Aug 13, 2015 06:07 AM
