Open Air Mods
Old Nov 2, 2000 | 01:32 PM
BLUE92RS's Avatar
Open Air Mods
When you install the open air on the rs and take of the stock air filter holder with the snorkel Underneath all that is like two plug things (Sorry dont no much about cars) i belive this to be the throttle body. Whatever it is does the open air just sit on the top and hookup without any mods?
Old Nov 2, 2000 | 01:35 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
If it's under the air cleaner then it's the throttle body. The two "plug things" you refered to are the injectors. The air cleaner just sits on top of the throttle body.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Nov 2, 2000 | 01:42 PM
BLUE92RS's Avatar
So then the open air just sits on top with no problems?? Correct
Old Nov 2, 2000 | 01:47 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
if you get the right open element. Your metal tube that runs up from your exhaust manifold can be taken off. allong with all the other factory air cleaner peices. The little thing that plugs in, can be just layed anywhere, It is your sensor that monitors what the temperature of the air going into your engine is. Some aircleaners have little holes that you can drill out or punch out to put this back in, but it isnt nessisary. you can just tape it up over by your ac drier(the silver cylinder on the passenger side).
Also the Breather tube can be left just sticking out, some put in aftermarket breathers.
Heres a pic that should help you. and like i said, since youre in omaha, if you are doing this today, i could help you, i have nothing to do after 3 oclock.
**I also own a shop, so i can get you a discount from napa. and a small one from hp motorsports for the k&N**
Call my Cell, 680-6045, I'll hook you up.
My name is Nic.
Gestapo?
ENGINE SPECS:
305 TBI,Open Element,K&N 14x3,Hypertech Stage I,160 Deg. Thermostat,454 GM TBI
STEREO SPECS:
JVC Kalmeleon kdlx3,Infinity Kappa 2way 6x9's,PPI 4x6 Coaxials,PPI PC2400 AMP @ 2ohm
DEI Studio 12" 4ohm DVC,Custom Box:Exactly 1 Cubic Foot
[This message has been edited by snflupigus (edited November 02, 2000).]
Brinkkl2000
Aug 4, 2018 08:29 AM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
mdtoren
Aug 23, 2015 12:52 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
