fuel filter issue help please!
Old Nov 23, 2006 | 05:16 PM
SAMRS350's Avatar
Car: 1989 Camaro RS
Engine: TBI 350 - Approx 300hp
Transmission: 700R4 (Soon to be Built)
Axle/Gears: 3.73's & Eaton Posi
The problem i face right now is that the fuel filter on my 89 rs hasent been changed in soo long that the fittings are rusted to the filter. I have a plan. My plan is to cut the fuel fiter out and replace that line with a straight through hose. The next part of my plan is to insert a fuel filter in the send line under the hood. I am wondering can i put a universal fuel filter between the steel lines and the rubber hose next to the alternator. i mean where the bigger hose and the steel lines connect to each other, can i put a fuel filter in there???? Are the fittings 3/8" NPT is what i want to know???? Please help???
Old Nov 23, 2006 | 06:18 PM
blackchevytruck's Avatar
Car: Chevy Truck
Engine: 350 tbi
Transmission: 5 speed
Axle/Gears: stock
I have the same problem with one of my trucks. Right now I am going to try to soak it down with penatrating oil for awhile and see if I can see get it off.
Old Nov 23, 2006 | 06:29 PM
deadtrend1's Avatar
when mine was stuck, I used pentrating oil and then vice grips rather then boxed end wrenches.
Old Nov 23, 2006 | 06:34 PM
MavViper's Avatar
When I changed mine out just recently it was the original one and was really tough to get off. Soak it in penetrating oil overnight and then try.
Old Nov 23, 2006 | 10:01 PM
SAMRS350's Avatar
Car: 1989 Camaro RS
I tried soaking them in penetrating oil a couple of times and that didnt work
Old Nov 24, 2006 | 12:10 AM
langss's Avatar
Car: Assorted
Engine: Various
Transmission: Manual and Automatic
Its Metric,use Flare Nut Wrenches,Soak the Fittings,Get new O-Rings in advance.Its under pressure,allow time for the pressure to bleed off. I would not replace a high pressure steel tube with O-Rings,with a rubber hose.FYI
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
