Help me build my 350 TBI
Old Nov 23, 2006 | 07:46 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Hey all
I have a 91 LO3 automatic car. Check out my VB garage for mods.
I got a L05 out of a early 90s Blazer and the ECM for it, and I am going to rebuild it. I have it stripped down and getting ready to send it out to get cleaned up and ready for rebuild. Its a 2 bolt, flat tappet motor with the provisions for a roller cam.
So I know nothing about engines, I am on an extremely tight budget. And I will be driving the car everyday. What I am looking for is help with what I should be buying and what I should stay away from.
I want to keep it TBI for the ease of the swap into the car, and I would like to run 87 Octang gas.
So give me some suggestions, this build is all up to all you guys.
Old Nov 23, 2006 | 08:36 PM
eschevyrda's Avatar
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
yea i was in the same situation as u sooooooo
best thing i did was to install a tpi fuel pump i got one for a buck new.
my motor was also used so i cleand the crap off and painted the block and replaced the gaskets
ahhhh tuneing one of the best things to do the car either do it your self or get it done
dude u mite as well replace the motor mounts and transmission mounts it makes a difrence and thier cheep
i was also on a tightbudget and the car is also my daily driver.
dude ive seen your car on eastcoast f body .com im also on that site
my screen name is eschevyrida hit me up
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
89-S-dime
Aug 12, 2015 11:57 AM
