comments on 305ci tbi to tpi conversion
Old Nov 27, 2006 | 03:53 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Hey, anybody experimented TBI mods like performer manifold, ultimate tbi mods, chipp burning, headers, highflow cat and cat back? Everithing keeping it emission legal!!!
I have a 91trans-am Lo3 and the car looks nice and fast but does not give me what I expect from a 5L engine. Is TPI conversion the way to go?
Old Nov 27, 2006 | 03:57 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have, what do you want to know about it?
I say TPI is NOT the way to go.
Old Nov 27, 2006 | 04:13 PM
thomas1976's Avatar
Car: 91 Trans am
I purchased tbi prformer manifold, extremefi 46mm tbi, walbro255, still loocking for headers and highflow cat + cat back. And asked miself If I really know what Im doing and admitt, not at all.
How mutch hp? Are you happy with it? Would you do it again? Any advise?
Than you.
Old Nov 28, 2006 | 08:15 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Than you.
I think you will hit close to 200 HP, IF you tune your ECMs Chip.
https://www.thirdgen.org/forums/tbi/...-tbi-mods.html
Old Nov 28, 2006 | 03:49 PM
thomas1976's Avatar
Car: 91 Trans am
Nice your post. How did I miss it!
200hp would be with the complete exaust right?
Old Nov 28, 2006 | 07:08 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Are you going to be reusing the L03 heads?? I had a L03 at one time also. I wanted to swap to TPI on my L03. Was told the heads are a little different on TPI 305's, so you might not get all the power that an original TPI 305 might have. I would recommend staying with the injection system that came with your car. Chip tuning will still be a large factor in any fuel injected Computer Controlled system. Changing that harness was the most difficult part of the whole engine swap, in my opinion. The old rule still stands though...Cubic Inches are the cheapest horsepower gain.
Old Nov 28, 2006 | 10:58 PM
Jeremy Z28's Avatar
Car: 92 Z28
Engine: LB9
Axle/Gears: 10 bolt/2.73
Than you.
I am still learning things myself, but here is my feedback. You are doing good so far. If you are not trying to be the fastest car on the streets, then the parts you have bought so far will give you a fun ride. The Walbro fuel pump is a good supporting mod if you want to really build your 305 or swap a 350 engine later. Definately pick up headers, and a bigger Y-pipe and catback with an aftermarket muffler. Don't forget to pick up the open element air cleaner, or at least the dual snorkel air cleaner that comes stock on the L69 equipped F-bodies.
After of all that, tune your computer and see where you are at. If you are satisfied, then good. If not, then there are other budget parts you can add, such as the stock cam from an LT1 or L98 engine, and the stock heads from the 305 TPI engine.
Take a look at my engine mod list, my car is a completely new monster compared to stock. I have not dyno'd it yet, but I know I am definately over 200whp, which is enough to satisfy me (for now). My car did not unleash its true HP until I had the computer tuned after the mods, which is one of the biggest factors in making power on our cars, and having them run right. For more info about tuning the stock computer, you can check out the DIY PROM section here on the boards: https://www.thirdgen.org/forums/diy-prom/
So to answer your question, No, I don't think you should swap to TPI, at least not yet. Wait it out and see if you become happy with your TBI + mods.
Old Nov 29, 2006 | 02:48 PM
thomas1976's Avatar
Car: 91 Trans am
Thanks for positive imput. Ill try and go with the suggested upgradings.
Old Nov 30, 2006 | 12:22 PM
techno101's Avatar
Car: 1989 Camaro RS
just don't get too carried away with your mods to TBI and then decide to change later- Swapping to a kick *** TPI is not cheap!
Old Nov 30, 2006 | 03:58 PM
thomas1976's Avatar
Car: 91 Trans am
Good point, wen you convert a tbi to a good tpi you need $$$$ to get started. Upgrading a tbi is possible by spending $$$ on a larger thime scale.
Old Nov 30, 2006 | 06:29 PM
techno101's Avatar
Car: 1989 Camaro RS
I can't stress enough...........no replacement for displacement
Old Nov 30, 2006 | 06:48 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Same here. I made 423 FWHP with a 305 TBI, but I bet it would have been 500 FWHP with a 350.
Old Nov 30, 2006 | 06:57 PM
techno101's Avatar
Car: 1989 Camaro RS
Damn!?!? Really? Boy I wish I would've none that before I ditched my L03! I went 350 TPI, can't say I regret it though. Love that Polished TPI.
Old Nov 30, 2006 | 07:12 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have gone sequential TPI as well. This is the test fit of the TPI intake on my 1983 G20 as I was pulling the Darts off my 350 TBI. This same intake setup went on a 305 in a 1994 G10 Van. The 305 TPI/4L60E combo was then run by a late model Vortec Express PCM and harness. Great running combo. In fact I have never seen another TPI Van.
Old Dec 1, 2006 | 06:43 AM
thomas1976's Avatar
Car: 91 Trans am
You must be eating tbi's for breakfast!
GM fastburn heads, World product heads or 305 TPI cilinder heads? For a LO3 with the erlier mentioned mods.
Old Dec 1, 2006 | 08:08 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
None of the above. The 2004 up ZZ4 Aluminum castings flow very well, have 58cc chambers stock, support like .525" lift out of the box, and are aluminum. A little bowl work and a back-cut on the valves will typically make them out-flow stock Vortec heads.
Old Dec 1, 2006 | 04:07 PM
thomas1976's Avatar
Car: 91 Trans am
Do you know a store where I can get them ready to bolt on?
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
