L31 Vortec Heads,,,,, Guided Rocker Arms???
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
I was lookng through my GM performance parts catalog and In the caption about the L31 heads it mentioned that I would need "guided" Rocker arms or aftermarket equivalent. Valvetrain lingo is far from my area of expertise so if someonw could enlighten me as to the meaning of "guided" when referring to rocker arms I would be greatly apprecitive. Also Can Roller rockers be guided? Just rying to cover the bases.
thanks,
Lars
'92 RS 305 TBI
K&N Open Element
Ultimate TBI mod's (thanks Pablo)
Cam[.442"/.465" x 218*/224* @ .050", 10:1 Hypereutectic Pistons
Performer Manifold
Shift Kit, Corvette servo,
and 2800 Stall Trans Specialties Converter,
Gutted Cat, IAT Resistor
MSD Blaster Coil, Accel Cap and Rotor
thanks,
Lars
'92 RS 305 TBI
K&N Open Element
Performer Manifold
these rocker arms are called "self aligning" because they don't have pushrod guideplates to keep them in place. Roller rockers can be self aligning. The 1.6 ones in the LT4 hot cam kit are self aligning. They have a little valley on the tip to keep it aligned on the tip of the valve stem.
Car: '92 RS
Engine: In pieces
So what you are saying is that If I get Rocker arms that are "self aligning" they will work just fine on the Vortec heads? I just want to make sureI get this right before I go out and drop money on theses things.
thanks,
lars
thanks,
lars
84z96L31vortec
Aug 20, 2017 12:16 AM
ambainb
Apr 25, 2016 09:21 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
