TPI CAM WITH TBI
Old Nov 29, 2000 | 03:03 PM
1989CamaroRs's Avatar
TPI CAM WITH TBI
can i use a cam that is for a 350 tpi for a 350 tbi
Edelbrock TES Headers, High Flow Cat, Edelbrock Catback, SSM Subframe Connectors
Old Nov 29, 2000 | 03:22 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
you can use any cam you want as long as its for an SBC
will the l98 cam run well? Sure why not.. dont expect it to be brutally fast though
Old Nov 29, 2000 | 04:10 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
it would be my thought that if you are changing cams, do it with the perfect one not just one you want to try. research and pick one that is perfect for you, tpi cam seems to me to be suited for tpi. look into something that will benifit your particular engine.
Old Nov 29, 2000 | 05:44 PM
well thats the the thing you dont see any cams made for 350 tbi just 305 tbi
Old Nov 29, 2000 | 07:11 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
305 engines, 350 engines, 383 engines, etc all use the same cams. Any cam made for a small block chevy will fit in any size small block chevy. The only difference is flat tappet, and roller cams. Flat tappet cams are in 86 and older engines, and roller cams are in 87 and newer engines.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 29, 2000 | 09:11 PM
Macgyver's Avatar
I think you should do some more research before yu purchase a cam.
You aren't gonna find a cam specifically made for a 305 TBI.
Old Nov 30, 2000 | 08:21 AM
FastBroker's Avatar
Comp Cams has a TBI specific roller cam that looks like it would be awesome! 258/264 adv duration, 206/212 at .050", .480"/.488" lift! 112 lobe sep, PN=08-500-8.
Any comments?
Old Dec 2, 2000 | 06:34 PM
NJ SPEEDER's Avatar
crane also has two different grinds available for tbi. i think i would consider the comp one for a 350, but the .488 lift sounds a bit big for a 305. most of what i have seen looks like once you get past about .460 lift in a 305 you start getting into valve shrouding issues.
lata
tim
91 Camaro RS-LO3,Auto.
14.301 @ 94.39mph
The car is going street strip for next season. 13's here i come!!!!!
Edlebrock TES Headers, Cat Eliminator Pipe, Borla Adjustable Cat Back,Marche Pulleys, HyperTech Chip,Transgo Shift Kit,B&M Convertor(2000stall),Steve Spohn Rear Rig( all rod ends), Poly Front Bushings,Ported TB, 350 Injectors, Edlebrock Performer TBI Intake, Performer Heads, 1.6 Roller Tipped Rockers
MustangBeater20
Oct 29, 2022 09:20 PM
evilstuie
Jan 9, 2020 08:29 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
