How do you adjust running to lean or rich
Old Dec 10, 2000 | 05:04 PM
BLUE92RS's Avatar
The reason i ask is because i am taking off my cat and read some posts saying you will lose low end power. It sounded like you would lose it do to running to lean. Should i just not do anything b/c i am putting in 3.73 gears and will have gained a whole lot of low end power.
If you disconnect your battery wont it adjust your air/fuel ratio anyway?
Old Dec 10, 2000 | 05:41 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
disconnecting your battery will just reset your computer. you computer adjusts whether you are lean or rich.
or you could boost your fuel pressure. new chip too would be correct solution.
[This message has been edited by snflupigus (edited December 10, 2000).]
Old Dec 10, 2000 | 05:44 PM
Andy89RS's Avatar
The reason you lose low end power isn't because of running lean or rich. Street engines have can profiles that work best with a certain amount of backpressure in the exhaust system. The reduction in backpressure at lower rpm is what reduces power, but only by a minimal amount. The power you gain at higher rpm more than makes up for it. Besides, who races at 2000 rpm anyway?
MustangBeater20
Oct 29, 2022 09:20 PM
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
tmellott89
Aug 16, 2015 02:58 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
