Lobe seperation w/MAP
Old Dec 8, 2000 | 11:41 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Does any one have experience with 110 lobe seperation w/TBI (MAP)
'83 Trans Am. 400 CID, 224/234 crane cam, Summit aluminum roller rockers, hand ported intake, home bored 2.09" (53mm) throttle bodies, MSD 454 injectors(75 lb/hr), Holley 255LPH fuel pump, custum modded FPR w/Vacuum port added, Edelbrock TES headers, empty cat, SLP 3" stainless steel cat back, stock ECM & chip. Borg/Warner T-5 World Class, 12" Corvette rotors and clipers, GTA 16" wheels, South Side Machine subframe connectors, 1LE sway bars, 3.45 ring and pinion, Alpine sound.
Best E.T. 13.532
Best MPH 102.24
Old Dec 8, 2000 | 12:08 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
i think grumpy does you might want to get in contact with him
Old Dec 8, 2000 | 12:27 PM
Engine: LT1, L400
Thank Pablo.
Old Dec 8, 2000 | 11:49 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Used a Comp Cam 270 for years with a 747 sytem. with 224 @ .050 took some doing but was great was done.
The VE tables look a little weird, but the car was fine to drive
Old Dec 10, 2000 | 08:28 AM
airbrushguy's Avatar
What is a 747 system? Could you possibly explain your problems and adjustments with that cam/MAP set-up, Grumpy?
Old Dec 10, 2000 | 02:06 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Airbrush guy
go here www.Diy-efi.org
go to the gmecm section
and then to articles
read Tuning Tips and read Programming 101 both written by grumpy on the basics of getting a given setup to work
Old Dec 10, 2000 | 04:20 PM
Outstanding, thank you Pablo.
Old Dec 11, 2000 | 09:15 AM
Engine: LT1, L400
Thanks alot for the feed back Grumpy. I found a roller cam on Ebay 230/236 @.050 110 LSA. I wondered if I could run it. Thanks.
Best E.T. 13.532
Best MPH 102.24
Old Dec 13, 2000 | 10:36 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Only since it's a big cube engine.
that would really be a stretch to do on a 350.
But your outta injectors.
Probably gonna need to find a set of the early BBC ones.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Jorlain
Oct 8, 2015 01:57 AM
skinny z
Oct 5, 2015 06:23 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
anesthes
Sep 21, 2015 10:24 AM
