winter diet q???
Old Dec 24, 2000 | 12:23 PM
NJ SPEEDER's Avatar
winter diet q???
someone mentioned taking the crash bars out of the door. how exactly do i do this?
thanks
tim
91 Camaro RS-LO3,Auto.
14.301 @ 94.39mph
The car is going street strip for next season. 13's here i come!!!!!
Edlebrock TES Headers, Cat Eliminator Pipe, Borla Adjustable Cat Back,Marche Pulleys, HyperTech Chip,Transgo Shift Kit,B&M Convertor(2000stall),Steve Spohn Rear Rig( all rod ends), Poly Front Bushings,Ported TB, 350 Injectors, Edlebrock Performer TBI Intake, Performer Heads, 1.6 Roller Tipped Rockers
http://www.mycar.net/mafb/registry/detail.cfm?id=299
Old Dec 24, 2000 | 01:27 PM
ONEFINE8T9's Avatar
just a quick question.....when u take those out what happens when u crash?
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
system: 2 10" MTX thunder 2000 in a Professionally done custom bandpass box.
Blaupunkt CD player
Blaupunkt 4x6 and 6x9
600 watt rockford fosgate 4.6 amp
http://members.aol.com/j007golden/Mikey89.html
Old Dec 24, 2000 | 02:00 PM
Basett Racing's Avatar
I took the doors off, removed door panels etc, and then rolled the window all the way up. I took a jigsaw with a metal cutting blade and enlarged some of the holes on the inside of the door. The I laid the door down on old tires and filled the door almost up to the impact beam w/ water. I then took my torch and cut the beam in the center, then cut it loose close to where it connects on each side. Then I worked these out from the holes I enlarged. The water will keep from warping your doors due to the heat.
I have heard of ppl acually cutting the whole inside of the door loose all except from the top, bending them upwards, removing the beams, then welding the inside of the door back on -- but I opted not to do it that way.
I didn't warp my doors and they work fine, they are a lot easier to shut and are a lot lighter.
1FINE8T9- Side impacts would be VERY bad, I suppose, but I have 8 point cage that would probably do as good as the original impact beam.
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
http://www.bassettracing.cz28.com
Old Dec 24, 2000 | 02:12 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Basset, how much did the beams weigh?
and any idea on whether the earlier thirdgens had lighter beams? I notice that my 84z's doors seem to be lighter than my 89, they swing easier
Old Dec 24, 2000 | 11:53 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
harwood sells fiberglass doors for our cars. and front quarter panels and of course hoods.
doors i think are 150 a peice
IM: snflupigus | ICQ: 96787192
Snflupigus.com
Open Element Tech Article
ENGINE SPECS:
Stock Rating: 170bhp & 255ft-lbs
305 TBI,Open Element,K&N 14x3,Hypertech Stage I,454 GM TBI
Now Rating: A Little More
STEREO SPECS:
JVC Kalmeleon kdlx3,Infinity Kappa 2way 6x9's,PPI 4x6 Coaxials,PPI PC2400 AMP @ 2ohm
DEI Studio 12" 4ohm DVC,Custom Box:Exactly 1 Cubic Foot
Old Dec 25, 2000 | 01:38 PM
They weighed around 35# each est. I didn't actually weigh them, but I weighed the car after I removed them and a few other things and I saw about about a 85# difference and the other stuff weighed about 15#
bjpotter
Oct 15, 2015 11:07 AM
tmellott89
Oct 14, 2015 02:06 PM
meeklay812
Oct 1, 2015 03:46 PM
Formula8r89
Sep 22, 2015 04:24 PM
86White_T/A305
Sep 21, 2015 05:28 PM
