i need help with vss
help. i have a 92 rs tbi auto. i have a problem with the speedo. it jumps all over the place until it gets warm and sometimes won't work at all. what is involved in changing this and is there anything else i should check. also what should i do to get better performance without puttin in a 350. thanks.
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
The boards have been slow all thru this month.
Your other post was deleted due to it not following the terms of agreement of using the boards.
Sorry there wasnt somebody who could help you with your problem, but you need to calm down.
Next time you need help. The first thing you do is search for keywords.
Go to search and type in vss. You could have solved your problem without ever posting a thing.
Here is the info you could have found.
https://www.thirdgen.org/messgboard/...ML/000358.html
IM: snflupigus | ICQ: 96787192
Snflupigus.com
Open Element Tech Article
ENGINE SPECS:
Stock Rating: 170bhp & 255ft-lbs
305 TBI,Open Element,K&N 14x3,Hypertech Stage I,454 GM TBI
Now Rating: A Little More
STEREO SPECS:
JVC Kalmeleon kdlx3,Infinity Kappa 2way 6x9's,PPI 4x6 Coaxials,PPI PC2400 AMP @ 2ohm
DEI Studio 12" 4ohm DVC,Custom Box:Exactly 1 Cubic Foot
[This message has been edited by snflupigus (edited December 31, 2000).]
Snflupigus.com
ENGINE SPECS:
STEREO SPECS:
As for speed....
Headers, there are many companies that make 3rd gen specific headers with or without emmissions tubes.
Rearend gears, you have 2.73 most likely, change to 3.45 or 3.73's
Edelbrock Torquer 2,Performer, Weiand Stealth, single plane. all will work better than stock
1.6 rockers.
Upgrade ignition system. MSD is what the pros use. Jacobs is great but expensive.
Computer chip. to many to list.
Take out your cat if you dont need an emmisions check every year.
Open element air filter.
NOS. gotta be careful
Supercharger. Expensive
There you go... Hope this calms your flame.
1.6 rockers.
In that last reply, I was just trying to get someone to respond. I wasn't trying to make it look as it did. I finally got the vss thing fixed after the 3rd one. now i have to change the driver power window motor. I can't do too much on the performance side of the house until I get back too Oklahoma. Right now I'm stationed in Korea for the Air Force and my wife has to stay in Texas until next June. Then that's when the car will be basically rebuilt. I do have a question for you though. Will any 350 TBI of the same year or later work with the 305 computer? I'm gonna get one when I get to Ok, but need to know if the computer has to come with it or not. This motor will be built up with vortec heads and I'm expecting it to run in the low 14's to high 13's with out too much internal work.Thanks for the infor for the speed parts. It was much needed. Thanks again. I hope I didn't affend anyone. Jason
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Jason:
The computer for the 305 TBI and the 350 TBI is the same (8746) but the chip is different.
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I think your biggest problem will a 305/350 swap will be the injectors...swapping to 350 injectors will require another computer chip.
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
Performance:
Electronics:
Ok, that sounds reasonable. So would I have to go with a custom burned chip or get mine recalled to work with the 350 injectors? I want to put a better chip in, but I want one that will work at low speeds and not just at WOT. Any advice?
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
