Car Running Hot all of a sudden..Help!!
Old Jan 16, 2001 | 11:40 AM
92red'maro's Avatar
I have a 92 Camaro RS that I store for the winter but about once or twice a week I start it and take it for a short drive. Last summer I put a Low Temp Thermostat in it that worked great. All of a sudden the Temp is gettin real high when the car is just idling... any ideas what is wrong??
Old Jan 16, 2001 | 02:42 PM
pianiy's Avatar
Did you change the chip when you swapped the stat? Its a mod that should be done together to adjust the computer for the different temps when the fan is supposed to come on.
~Luke a.k.a. pianiy = drunk (in Ukrainian)
"The world would have no problems if everyone had a presence of mind."
'91 Firebird
305/TBI(L03)/700R4/T-tops
Mods: Catco high flow cat - B&M Shift kit - TA tail light conversion - K&N - MacEwen white faced guages
Stereo: Pioneer DEH-P8200R - Pioneer 6x9's - Kenwood 8" Tube
'87 Firebird
LB8/700R4/220K - Twas a good car until the accident.
Firebird parts - Now with an '80 Firebird for sale!
Moderator of tranny board over at TransAmGTA.com
[This message has been edited by pianiy (edited January 16, 2001).]
Old Jan 16, 2001 | 09:04 PM
92red'maro's Avatar
i didn't change the chip.. it was running fine, never got above 170 or so at all at any time. All of a sudden though.. it is running hot. What chip should I get??
Old Jan 16, 2001 | 10:44 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Just at idle? Check to make sure that your fan is coming on when it starts to get hot.And you might want to check your water pump.
Old Jan 16, 2001 | 11:42 PM
jeff88convertible's Avatar
I would check and make sure your air damper is still there(located right below radiator)and if it isnt cost is about $30 dollars. If thats not it make sure if you have an electric fan that it is running. One time I had to bang it with a screwdriver to get me home in the heat of sunner. Sometimes the radiator can get dirt and other debris get caught in the element. Take a air hose and blow out from other side. Also try flushing system out. If thats not it check your timing thats all i know good luck!
88 camaro rs convetible 92 rims / flowmaster/ hypertech chip/ 3.73 gears/tbi spacer/open elemnt/hollowed cat/shift kit corvette servo/k&n filters/holley tbi unit/nox squeeze/future mods 350 with 400 crank/sub frame conectors
theshackle
Mar 5, 2017 06:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
